Results 1 to 12 of 12
Thread: Shift lever recommendation
    Jun 2017
    Norway
    I am looking at shifters for a T56 Magnum in a roadster. For those of you with this tranny, which would you recommend? 6 Inch 30 degree bend, or 8 or 10 inch, straight or 30 degree bend? Not sure if I can go midshift. What have you chosen?
    On a roll Al_C's Avatar
    Wheaton, IL
    I did the mid-shift mod, although I did it on a TKO600. This is the shifter I went with: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    There was a thread here some time ago (sometime early 2017 maybe?) that discussed different shifters and the one listed above seemed to be a favorite. I know at least one builder modified the shifter to shorten it somewhat. I think this thing will fit a number of different applications.
    Raleigh NC, OIB NC
    I have the 427 shifter from ********** $99 now was cheaper a few years ago.
    Kevin
    MKIV #8234
    Senior Member Paul2STL's Avatar
    Nov 2012
    Tacoma, WA
    2X Same here and I have the T-56/Coyote combo, love the tranny shifts like butter and the handle lands in a perfect positon to shift right off the steering wheel.
    MKIV #9122 Ordered kit 5/24/17 received kit 8/11/17 MK4 Base kit +,First Start 4/7/18, First Go-Cart 4/22/18, In gelcoat, licensed and driving 8/11/18. Coyote gen2, T-56, 2015 IRS 3.31, 17" Halibrand replicas w/Nitto NT555 G2, Withby Motorcars power brake kit W/Wilwood pedals, 04 Cobra front brakes, 15 Mustang rear brakes with mods, power steering. Paint Jeff Miller Da Bat, Lexus Spectra Blue Mica W/Toyota Silver Sky Metallic strips. Build thread: http://thefactoryfiveforum.com/showt...Paul2STL-Build
    Jun 2017
    Norway
    Thanks guys. Went with the 6" 30 degree angle one, hopefully it'll fit nicely. Gotta stop buying parts now, and wait until I have the car. Still waiting for it to be picked up by Stewart.
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Not to add to your thought process, I used the shifter from my '93 donor. I just turned it 180* and it falls directly under my hand.
    Ray
    Copperhill, TN
    If you use the 427 shifter, be cautious of the lockout levers, they catch on sleeves, and actually cut me once. I’ve removed them.
    Folsom, CA
    how long is the shifter handle from f-line ?
    the straight FFR stock shifter handle seems to crimp the rubber boot quite a bit, I like the straight up and angled over version from other vendors
    also, what's the difference between the T5 and the TL versions? T5 says it fits FFR and 1/2 the price
    I have the coyote with TKX in rear position
    Todd
    Nov 2016
    "The i.e." SoCal
    Quote Originally Posted by toadster View Post
    Check out the one we sell. Satin Stainless Steel and solves the problem with the shifter boot. It even works with the Factory 5 provided knob.
    https://www.facebook.com/media/set/?...7881855&type=3
    Folsom, CA
    nice Frank! do you have a chrome or polished version?
    Todd
    Folsom, CA
    Quote Originally Posted by Blue Viking View Post
    where did you find a shorter version?
    Todd
    Nov 2016
    "The i.e." SoCal
    We do not. More options drive the prices higher and inventory/overhead cost. We chose the satin finish because it can easily be polished by the end user if wanted.
  13. Likes toadster liked this post
