Thread: Coolant Gauge Electrical Problem !!!!HELP!!!
    Apr 2019
    San Antonio
    Problem
    Electrical Gauge reading between 200F to 250 F. Engine at 180F
    What I have done so far and still not fixed.
    Replaced Thermostat
    Replaced Sending unit 287.4ohms to -22.7ohms 12v
    Replaced Gauge 287.4ohms to -22.7ohms 12v
    Run new wire from sender to gauge.
    Sanded all ground connection on frame and engine
    When I attache the MultiMeter to signal wire and ground it shows the correct ohms.
    I attach the Signal Wire to the gauge it will drop 100 ohms to like 20 to 60. thats like 200f - 250f
    Losing it, probably switching to mechanical coolant temp gauge\
    Thanks Timo
    Well, Brother, You're in San Antonio.....Maybe the guage is giving you the "Feels Like" factor....I know that doesn't help but just trying to lighten your mood. You have replaced all the (not so) moving parts.....unless, maybe, did you use teflon tape on the sending unit....is it one wire or two ?...da bat
    Apr 2019
    San Antonio
    no Teflon used.
    should there be voltage between the signal wire and ground, says 4 volts.67634233_10157522998399636_3826195684638326784_n.jpg
    sorry wrong picture
    Lost Wages, Nevada
    Quote: "Replaced Sending unit 287.4ohms to -22.7ohms 12v Replaced Gauge 287.4ohms to -22.7ohms 12v"
    Curious. just how do you measure -22.7 ohms??? resistance is resistance, there are no negative values in ohms that I'm aware of . . . no resistance = 0, anything that can create resistance will show as a positive number.
    I'm thinking you have a mis-watch somewhere between the sensor (which is grounded) and the gauge. OR you are taking ohm measurements at the wrong place.
    Also, How are you verifying that the engine is at 180°f ??
    Doc
    Apr 2019
    San Antonio
    i meant 287.4 to 22.7
    taking the reading of the coolant with a laser temp measure
    Assuming the sensor is the brass thing just behind the T-stat housing I see it's one wire. W/ key on, take the wire off the sensor and touch it to the engine ground which should send the gauge to it's max reading. I have never tested for V in the sensor wire but it seems there could be some coming from the gauge.
    RBachman's Avatar
    Jul 2019
    How is the backlight connected? Could that cause this?
    Apr 2019
    San Antonio
    found the problem, bad ground cable from gauges to ground. now everything works
    Jax Beach, FL
    Quote Originally Posted by Timo View Post
    Bad ground. That seems to be the answer for 95% of gauge problems. Glad you found it.
