Thanks Thanks:  4
Likes Likes:  5
Results 1 to 17 of 17
Thread: Hello, all! Researching a future build
    Jul 2019
    Georgetown, TX
    Hi everyone-
    I'm currently in Bellevue, WA, thinking about moving/retiring to (probably) Vegas in a couple years, where I hope to start a build. I've been wanting to an MK4 for quite a while, but the early version of the GTF looks pretty hot!
    If I go with an MK4, I'm torn between using a Coyote engine (I have a Roush blown '11 Mustang GT daily driver) or one of the more traditional builds. For the GTF, I'd almost certainly use a Coyote.
    If anyone has some thoughts, I'd love to hear them. In the meantime, I'll probably mostly just lurk in the fora.
    -Paul
    st george, ut
    I have a MK1 and a GTM if you want to see them. im thinking about selling the GTM. im about an hour south of you in Olympia by cabelas
    Jul 2019
    Georgetown, TX
    Thanks! If I'm heading your way, I'll ping you.
    Jul 2019
    coyote
    Quote Originally Posted by PaulRSchmidt View Post
    Hi everyone-
    -Paul
    well i'll give you my opinion of the Coyote in the roadster as a non-wrenching driver, definitely NOT as a builder.
    It sounds great with the FFR headers....wicked cold starts and absolutely screams with WOT, but while cruising you can have a conversation with your passenger no problem. i think with any transmission setup you'll be under 2k RPM in top gear at 65mph.
    it's power delivery is very smooth and it is on tap pretty much anywhere in the rev band. the coyote does not have a reputation as a low-end torque monster but in a 2300lb car it's a different story. it feels like the fastest car I have ever driven and I have not gotten anywhere near it's limits.
    i also love knowing it is going to start, idle perfectly, and run without overheating issues every time I turn the key.
  5. Thanks PaulRSchmidt thanked for this post
    Senior Member brewha's Avatar
    Somers, Ct
    Welcome
    If your a Roush fan, here’s an option for you. If you go to build school which is definitely worth it, you can go to the Roush factory 20 minutes down the road for a tour and talk to the builders.
    Mark4 - 331 Stroker - Fitech 600 -TKO600 - Moser 3.55
  7. Likes PaulRSchmidt liked this post
  8. #6
    Similar question was asked a few weeks ago with lots of responses. Take a look: https://thefactoryfiveforum.com/show...ndianapolis-IN
  9. Thanks PaulRSchmidt thanked for this post
  10. #7
    Lilburn, GA
    Vegas... HOT!..... Something with air conditioning!
  11. #8
    Jul 2019
    Georgetown, TX
    I know, I know. But it checks all of our other boxes....
  12. #9
    Jul 2019
    Georgetown, TX
    After reading some of the other threads, I'm very much leaning toward the Coyote even for the Roadster based on driveability, etc, but as an old-school American muscle car fan, can I get a deep burbly sound out of it? All of the Coyote Mustangs with aftermarket exhaust are buzzy and poppy.
  13. #10
    I promise you, nobody will ever mistake the sound of the Coyote with FFR or Gas-N side pipes for a Mustang. Totally different sound.
    I love the sound I get from my Gen 2 Coyote with Gas-N pipes at every RPM range. That being said, it idles smooth. It growls when you put your foot into it, but If you want that rumbling, loping, raw sound at idle, go old school.
    It may be possible to tune a Coyote for a loping idle or even change cams... I'll leave that to others.
  14. Thanks PaulRSchmidt thanked for this post
  15. #11
    ...can I get a deep burbly sound out of it? All of the Coyote Mustangs with aftermarket exhaust are buzzy and poppy.
    Coyotes in the roadster (and Coupe) sound entirely different than they do in a Mustang. Additionally they are different from one another depending on the exhaust configuration---I've had cars in the shop that used 4 into 4s with FFR pipes, J-pipes into FFR pipes, 4 into 4s into Gas-N sidepipes and J-pipes with Gas-N and the variation is significant (if anybody cares my personal preference is 4 into 4s with Gas-N )
    Just remember that engine type and configuration has a lot to do with the equation so things like compression, displacement and cam specs really come into play.
    We've got three guys in my area, in addition to me, and we all have the same pipes. They are running 4 into 4's while I've got a 3" collector and a 3/8" clover leaf in between my headers and pipes.
    From Mild to Wild they are shown below regarding the level of ear hurting that is taking place:
    Aaron 331 SBF
    Donny 396 Ford Edsel (FE Big Block)
    Heath 351 SBF Windors
    Me 383 SBC (Dart)
    I really think that a Coyote will sound a lot different, but I don't think it will sound very buzzy, poppy or anyway near tin can like.
  17. #13
    As several have said, a Coyote in one of these doesn't sound anything like a Mustang. All due respect to my Mustang buddies, I consider that a good thing. Will also point out that the Gen 3 Coyote (2018+) sounds more aggressive than the Gen 2. Just posted these videos earlier this week of the Gen 3 Coyote running in my Coupe build. Turn up the volume!
    https://www.youtube.com/watch?v=24kZChAlKeI
    https://www.youtube.com/watch?v=QCdUdj6n3eM
    https://www.youtube.com/watch?v=mFHHqadaREs
    As already stated, different sidepipes and different headers can alter the sound some. These videos are with prototype Coupe Gas-N headers and sidepipes. But it sounded similar with Roadster Gas-N headers and sidepipes that I used during the first starts. Sounds a bit deeper and angrier than the GP Headers and Gas-N sidepipes in my Gen 2 powered Roadster.
    Most typical Coyote tunes, including what I've used, don't have a big lope at idle and have to say I'm pretty much over that. But it is possible to to do something called a "Ghost tune" where they move the cams around and produce a similar sound. Most tuners offer them. Not my thing but it's possible. This in a Mustang: https://www.youtube.com/watch?v=MF5rAQMJfY0.
  18. Thanks PaulRSchmidt thanked for this post
    Likes GoDadGo, Kmcallahan liked this post
  19. #14
    Jul 2019
    Georgetown, TX
    That sounds great! Thanks for those. I’m pretty sold at this point.
  20. #15
    Thanks. Glad you like it. Just to be clear though, that's a Gen 3 Coyote (2018+) which is relatively new on the scene. There are a couple builds using it that I'm aware of. But nearly all the builds on here will be either Gen 1 (2011-2014) or Gen 2 (2015-2018) with Gen 2 maybe being a little more typical at this point. The Gen 2 in my Roadster doesn't sound quite as angry as the Gen 3 videos I posted. But either way, it's a great choice. Good luck.
  21. Likes Kmcallahan liked this post
  22. #16
    Kirkland, WA
    I intend to try out the ghost cam for a while. It's only enabled when the engine is at full temperature and idle. As soon as you start to accelerate, the computer phases the cams back to normal.
    It seems like many modded Mustangs these days have a specific exhaust note that I associate (right or wrong) with SpinTech mufflers, and the tone isn't to my liking. I grew up on cherry bomb glass packs, so any 'shaping' or tone control doesn't sound right to me. Just give me a deep, rumbling bass.
  23. Likes PaulRSchmidt liked this post
  24. #17
    BadAsp427's Avatar
    Greeneville, TN
