Results 1 to 5 of 5
Thread: Russ Thompson Turn Signal Switch Problem
Hybrid View
    Nov 2016
    Petaluma, CA
    I am using the Russ Thompson turn signal switch on my 289 FIA. All the lights work with the exception of the right turn signal. Some time back, I recall someone else having this issue and sharing the solution in the Forum. I cannot for the life of me find that post. Can anyone help me with the solution to this problem? Thank you. Joel
    Nov 2016
    Petaluma, CA
    Another try. Anyone? Thanks
    Senior Member Paul2STL's Avatar
    Nov 2012
    Tacoma, WA
    First check you connections on the wires make sure that are good. Some times the contacts inside the arm don't make a connection you might have to pull it apart and put some dielectric grease on the contacts. I had problem with the left signal not coming on. Opened it up and made sure when the arm moved it made good contact. Look it up on UTube for Karmann Ghia turn signal repair. They are rebuilt units from him so they may need some attention. Call Russ if you have a problem he is always willing to help.
    MKIV #9122 Ordered kit 5/24/17 received kit 8/11/17 MK4 Base kit +,First Start 4/7/18, First Go-Cart 4/22/18, In gelcoat, licensed and driving 8/11/18. Coyote gen2, T-56, 2015 IRS 3.31, 17" Halibrand replicas w/Nitto NT555 G2, Withby Motorcars power brake kit W/Wilwood pedals, 04 Cobra front brakes, 15 Mustang rear brakes with mods, power steering. Paint Jeff Miller Da Bat, Lexus Spectra Blue Mica W/Toyota Silver Sky Metallic strips. Build thread: http://thefactoryfiveforum.com/showt...Paul2STL-Build
    Elk Grove, NorCal
    Joel
    Assuming the connections on the RT turn signal are solid: If you used the supplied electronic trailer module with 3 input wires to 2 output wires, those often fail. I bought a powered one and that failed on me also with only 1000 miles. I went back to the diodes. Only problem with those are when you have a turn signal on, and you step on the brakes, the turn signals cancel with only the brake lights illuminated. This mod is only for the rear lights. If the front turn doesn’t work then it’s something else.
    Sorry for the late reply. I just saw the thread
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
    Lilburn, GA
    I had a problem with one front turn signal. It took me hours, verifying the setup and connections, looking for the problem. Turned out the problem was with the FFR supplies wiring harness. Where the front harness plugged into the main harness, the green and tan wires at the harness coupling plug were backwards. Green in = tan out and vise-versa.
