My 818 had a fire at the end of last year that completely burned the rear of the car. I decided to rebuild it without the body, kind of an exo-818. The front end body components were damaged but are repairable if anyone can use them. I have basically the entire front end available, body components, structural components, aluminum, etc.
I also have the factory five fuel tank available that I did not use.
I have an unused windshield frame and windshield glass.
Fuel Tank
The fuel tank has been sealed inside and out with KBS fuel tank sealant. Some additional baffling has been welded inside to help with fuel slosh. A fuel vent rollover check valve has also been installed. Includes fuel pump and fuel sending unit.
I can ship the fuel tank.
Windshield and frame
Unused windshield frame and windshield glass.
Fenders
Left and right fenders including headlight assembly. The top of the fenders were burned in the fire and will need to be repaired. The gelcoat burned off. Also, the headlight covers will need to be replaced. Includes carbon fiber dive plates. Left side dive plate has a bubble from the heat. The fenders are structurally fine but the tops need some fiberglass work.
Hood
Similar to the fenders. Gelcoat burned off at the rear and will need to be repaired.
Front end structural components
Already assembled as pictured. Includes aluminum panels and grill.
Front nose/grill
No problems with the nose and includes brake cooling ducts
Carbon fiber splitter - SOLD
No problem from fire. Wear from installation and normal use. In good condition.
These parts are really too big to ship so you will have to pick them up in North Alabama (Huntsville area).
Make offer
PM me with any questions
Skip
Reason: Update
