I have a Bluprint LS 3 and the FF cluster gauges. It calls fo the temp sensor and oil pressure sensor to install into the block. Can I wire off the LS sensors already installed. They look exactly the came. I don’t see any empty ports to screw in the FF cluster sensors.
If anyone knows where to add the additional sensors or wire off existing sensors. Please help. Thanks
