Results 1 to 4 of 4
Thread: Steering Column Issue (Gen 2 Frame)
    Jan 2019
    went to install the steering column. The top bracket went in a little snug, but the bolts slid right in.
    Went to install the lower bracket in the top bolts on the frame and they do not line up with the slot in the column.
    I'm debating whether it is better to clearance the slot on the column or drill the hole in the frame to fit.
    Any advice?
    Neither. It will massage in. Take the top bolts loose and wiggle. Get them all in and then tighten. There’s a ton of play in the system even though it feels snug.
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
  3. Likes AJT '33 liked this post
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    Mine was snug too but if you put all the bolts in loosely they will go in.
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
    Jan 2019
    I ended up oversizing one of the holes in the frame at the top of the column. I'm surprised how much I had to stretch the lower bracket , but it fit.
