0
0
Metco Driveshaft Loop Interference
Hey guys. I installed the Metco Safety Loop today, and am getting pretty good interference with the e brake cables, as they are semi tight against the side of the loop if I have the bracket perfectly centered. I have the e brake mod with double wheels.
I could move the bracket a little to the drivers side about an inch to get some slack but then the loop is not centered on the driveshaft and not completely comfortable with that, as if the bracket happened to move a bit after installation for whatever reason it could make slight contact with the drive shaft.
Anyone else have this issue?
