4
Engine problem
On my last two drives, my engine (Ford 302 with Holley Terminator fuel injection) has died. Both times I've been able to immediately start it up again.
The first time, it died after I had driven 1 1/4 mile from the house. I was doing ~25 mpg, in 2nd gear at ~2200 rpm. The second time, it died after driving ~1/10 mile from the house. Again, I was doing ~25 mpg, in 2nd gear at ~2200 rpm. After coming to a complete stop I was able to immediately start the car, and continued both drives without incident - not so much as a stumble.
When it dies, the car feels like it's being starved for fuel. All of a sudden, the engine bogs & rpm's drop. Pushing in the clutch has no effect, nor does giving it more throttle.
The car only has 2200 miles on it. I don't think it's the TFI module overheating because I can immediately restart.
At my last fill-up, I was low on gas & had to add gas while the fuel truck was filling the underground tank. Could I have a piece of sediment that temporarily clogs the fuel pump pickup?
MK IV Roadster #8631
