Results 1 to 14 of 14
Thread: Front overrider mounting
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    3699F35B-90A3-4345-9863-8E64D7FD2DDB.jpeg822DB42B-0E19-4E6B-A733-B0808004A9F6.jpegB7DCB6B7-CEA5-4FFD-AA7D-FAE1BACB32EE.jpeg
    I had a local tool shop modify my FRONT quick jack bolts allowing me to mount overriders without any issues. Take a look at the photos, let me know what you guys think!
    Senior Member dpariso's Avatar
    Aug 2017
    Beach Park, IL
    Sweet! I like the mod... its clean
    Norton, MA USA earth
    Curious where you got those over riders? Not FFR. You might find they will look a bit funny straight up and down on the front. The FFR supplied ones are angled out at the top to follow the angle of the nose opening.
    Tybee Island, GA
    Looks good!
    Videos are at: YouTube Videos
    I had the same thoughts.
  6. Likes chuckster liked this post
    Apr 2019
    NC
    They appear to be from **********.
    You couldn't ever add a hoop to those, and have it look good, with them sitting vertical like that. Not that was ever in your plans.
  9. #8
    Those are def **********. I have the same ones. Installing the rears is going to be, um, interesting.
  10. #9
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Finish Line Over Riders
    I have the finish line over riders and I'm using smaller diameter bolts on the front with different lengths, longer on top and shorter on the bottom and several washers. On the rear I"m using a modified
    "Kleiner" mod and brackets I made to attach the over riders to the threaded rod.
  11. #10
    Nov 2015
    Mount Olive AL.
    So it’s back to the drawing board! I did not realize the front over riders were tilted to match the front end angle. Thanks for the info. I’ll be back!
  12. #11
    You can tilt them by adding a few washers...…..The "Kliener mod" don't even get me started...da bat
  13. #12
    Quote Originally Posted by jrcuz;377135...
    "Kleiner" mod
    YES!!! Now we're modding the mods...I love it
    PS---Miller is right; you don't want to get him started. And you definitely don't want to let him into your house after 8PM unless you're prepared for a loooooooong night.
  14. Thanks jrcuz thanked for this post
  15. #13
    O'Fallon, MO
    Saw off the front of the nose, then bond it back on straight up an down. Either one of the Jeff's can fix that right up.
  16. #14
    Nov 2015
    Mount Olive AL.
    Got enough body work to do without sawing off the nose of the car! But I like the idea!
