Likes Likes:  3
Results 1 to 4 of 4
Thread: Engine install
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    Engine install
    Today the motor and transmission got installed thanks to these guys.Resized_20190810_143612_2504.jpegResized_20190810_142937_8669.jpeg20190810_173734.jpg
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
  2. Likes wrp liked this post
    Seasoned Citizen NAZ's Avatar
    That engine is old skool kool! When I was a teen in SoCal and these cars (the real ones) were popular, most had SBC power with iron heads and the three deuce set-up was the common performance induction of the day. I love that look, brother.
  4. Likes wrp liked this post
  5. #3
    Apr 2019
    Milford NH
    Thank you Naz. I loved the engine when I found it on fb for sale. Knew it would be great for this project.
  6. #4
    Apr 2019
    Milford NH
    I ended up taking the tri-power set up off and installed an Edelbrock performer manifold and AVS2 carburetor. It runs awesome. 20191006_145518.jpg
  7. Likes FF33rod liked this post
