Results 1 to 3 of 3
Thread: Front coilovers
    Jan 2019
    Mitchellville Iowa
    Front coilovers
    Which is the correct hole to use, upper or lower to attach front coilovers to the upper control arm on a Gen 2?
    Most photos I’ve seen posted use the upper. Someone at FF5 suggested the lower.
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    I used the uppers. I've been told the lower are for the truck
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
  3. Thanks Dduty thanked for this post
    May 2018
    Pinckney, MI
    Here's what I ended up with for my Gen 2. I will be running full fenders. For the rear 3-link, I'm still finishing up. Needed a new rod end.
    - I used the lower hole in the lower control arm mount and have the bolt pointing up to get a little more range of motion for the lower arm.
    - I used the upper holes in the upper control arm as I think that works better in mounting the Radiator.
    - I used the lower holes in the upper control are for the upper shock mount to get a bit more preload and ride height for the full fenders.
    I figure all of this will work out just fine once I get it all together.
    Update Jan 8, 2020
    - Used the upper hole for the lower control arm for consistency. However, needed to relocate the grease fitting to clear the steering rack.
    - The spring adjuster is 2.9 inches up the black collar. This puts a bit of preload into the system and with a preliminary fitting ride height looks about 5 at the frame and about 6 at the radiator. Exact dimensions once the Rear is adjusted.
    Last edited by peterh226; 01-08-2020 at 07:18 PM. Reason: Changed to upper hole on the lower control arm.
    - Peterh226 #1134
