Thread: New member from WI
    Aug 2019
    New member from WI
    Hi all,
    New to FF and this blog. I am looking to gain advice and hopefully help out others as I learn throughout this build. I had an 84 trans am that I sold in college and bought a 78. I still have the 78 ,but am looking for a project where I donít have to do rust repair and that has greater speed potential. The type 65 seems to be the way to go. I am excited to get building.
    Aug 2018
    Hampshire, IL
    Welcome, And congratulations I see you are already building. I had the same thought process with building new rather than rebuilding a rust bucket. I’ve been there done that several times. When I put the pencil to the paper and figured time and money involved building new was the way to go for me. I’m in the west suburbs of Chicago building a truck but have had to take some time off of it because of my busy season with work. Good luck and have fun with your build. Rob
    FFR 35 p/u # 0016 Dart 347 TKO 600
    Aug 2019
    Thank you. The truck looked very nice as well. A nice addition to the offerings at FF. I considered the roadster hard top and the truck myself. I went with the type 65 so it could fit above my firebird on my 4 post. Todd
    Kirkland, WA
    Nice to see some Pontiac love!
    Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, Roller: 12 Jan 2018
    Forte: 2016 Coyote & cover, alternator, engine controls, clutch kit, bellhousing, Moroso pan, TKO600, midshift, 3.55 axle, 190lph fuel pump, Spectre air inlet and filter. Breeze: battery forward and switch, fuel pressure regulator and braided hose, radiator shroud and mounts. Replicaparts: radiator panel, under dash panel, weathertight connectors.
    Senior Member gtaroger's Avatar
    Trenton Mi
    Welcome to the forum. Roger
    Senior Member ILPBFoot's Avatar
    Kildeer, IL
    Welcome Roger! I’m driving in gel coat. I miss the building and am loving the driving and working out issues. Good luck!
    Mk4 Roadster #9319, complete kit Received 4-10-18. On the road with IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, w Holley 750 with vacuum secondaries, manual Choke, 501 hp with 498 lb-ft torque. 404 hp & 431 lb-ft torque @ rear wheels. TKO 600 0.64 OD
