Results 1 to 3 of 3
Thread: Side Pipe Baffle Rattle
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Starting to get a slight rattle out of the drivers side, suggestions to correct?
    Dec 2012
    Houston, Texas
    I drilled a 1/16 hole from the bottom back so not visible and screwed in a long sheet metal screw until it hit the baffle. No more rattle.
    Phil: FFR 3121, Frame #2050, Mk 1.5, built 2002, 1991 donor with Blueprint 302 long block and 1993 Cobra intake, BBK 70mm T/B, no smog, power steering, T-5 and 3.55 rear.
    Tybee Island, GA
    I just went through something similar, and it turned out to be the hanger that was welded to the sidepipe had separated causing the rattle while driving. Here's the THREAD from my experience with some suggested ideas of what the rattle may be.
    Hope this helps.
    Videos are at: YouTube Videos
