Thread: Need some Subaru Expertise.
    Jan 2019
    Please give me your thoughts. Engine is a 2006 2.5L STI
    Looking for a reasonable flat torque curve. 450 ft/lbs. 450 to 500 hp. Running 2” headers and up pipe, 72mm throttle body, ported and matched intake no TVG.
    Was considering these 2 turbos.
    STS Turbocharger 3" Anti Surge TD06SL2-25G 8cm for SUBARU WRX STI
    Turbine Housing:8cm / AR.57
    Compressor Wheel:Billet 6 + 6 Wheel
    Turbine Wheel:9 Blades Wheel
    Wheels Spec
    - Compressor wheel: 60.2 / 78.0 mm ( Workpiece 25 g 6 + 6 blades / max Boost to 5.0bar)
    - Turbine wheel: 61.0 / 54.1 mm (9 blades)
    Compressor Housing
    -Floor area: ap.60
    - Compressor inlet: 3 " Anti-surge
    -Compressor Output:
    Turbines Housing
    -Size of nozzle: 8 cm / ar.57
    -Turbine input: for Subaru single Scrolling type
    - Turbine output: for Subaru single Scrolling type
    Bearing Type
    -System of bearing system (high-speed bearing set)
    Cooling Type
    -System of oil and water cooling
    Drive Pressure
    - 1.0bar The drive will go with the turbo.
    -We have 0.5bar, 0.8bar, 1.2bar, 1.5bar, 1.7bar and 2.0bar drives, Please add a comment to your order if you need to change it.
    Boost / HP
    -Max l. s .: 400 ~ 500 liters. from.
    -The acceleration is limited: 2.8bar
    -P3" TD06SL2-601-8cm
    reposed beat: 1.5bar
    OR
    3" TD06SL2-601-8cm
    3.15" TD06SL2-601-8cm2 Ball bearing Billet Wheel Turbo for SUBARU
    APPLICATION EJ20/EJ25 IMPREZA/WRX/STI/GC8-GDB 3.15 inch Cover
    ARASHI ITEM No. SU03S-03004K
    REPLACEMENT For. REQUIRE EXTRA 3.15 INCH PIPE
    TURBINE WHEEL TD06SL2
    TURBINE DIAMETER 54/61mm(9 Blades)
    TURBINE A/R 57
    TURBINE NOOZLE AREA 8cm2
    COMPRESSOR WHEEL 601 (Billet)
    COMPRESSOR DIAMETER 59/76mm (7+7 Blades)
    COMPRESSOR CFM 750
    COOLING Water & Oil Cooled
    BEARING Dual-row ceramic ball bearing
    PACKAGE INCLUDED Gaskets , extra springs and Install Kit
    FLANGE STANDARD SUBARU SINGLE SCROLL
    ACTUATOR 1.1 bar spring pre-installed on adjustable actuator.(18 ways for application)
    DESCRIPTION MAX HP 460+./ Brand New and Complete CHRA balanced by Turbo Technics.
    *Contact us For any inquiries or special requests such as larger amount ordering
    Sgt.Gator's Avatar
    Bend, Oregon
    I'll make the general comment that if you are installing in the stock location with the intake tube going under the intake manifold that a 3" turbo is a pain to install. I have that on my STI and I swore I would never do a 3" again in a stock location. According to the tuners I've talked with they see virtually no performance difference between a full 3", a 3" with an adapter necking down to the oem size intake, and an oem size turbo inlet at less than 450 HP. To do a 3" well you'd want to go rotated or neck it down with an adapter, which is often included in the kit. I know ATP includes them with their 3" Subaru turbo kits.
    My other comment is are you sure you want 450TQ /450 -500HP? Trying to use that much power on the street, or even on a track in racing conditions, is not easy in a 2000 lb car with two wheel drive.
    As for the choice of turbos, I personally stick with Garrett or Borg Warner cartridges; externally gated. Today we're first starting an Outfront closed deck 2.5 with a ATP 3576 built in externally gated turbo. I expect it will be great in my 3000 lb AWD STI, but would be too much in the 818R. And yes it has the 3" inlet, but only because I had it all left over from the prior engine and turbo. If I ever go this big again on a new build it will be rotated.
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Jan 2019
    Thanks for replying, Yes it will be rotated, I decided after hearing no response that I would go one step smaller in a TD06 20G ball bearing gtx wheel so MAX 420hp. I figured this would come in sooner and give me the flat torque curve I am looking for. As this is a track car I can always pull power but I cant add it easily so to speak. Plus I am planning on having traction control with the Haltech ECU.
  4. Likes Mitch Wright liked this post
    Jun 2017
    Gator, was that even with the large "phenolic spacers" on the intake manifold? I believe those help with the larger inlet.
    Jan 2019
    Quote Originally Posted by grabera7 View Post
    I too have those spacers. I miss wrote I ordered the TD06SL2 20G 11blade GTx
    Sgt.Gator's Avatar
    Bend, Oregon
    Yes. In fact I don't think it's possible without them. If you use the 3" special offset silicone hose from Agency Power it's easier. But I still wouldn't do it again. Plus the 3" bend at the power steering pump is another problem, but obviously not on a manual rack 818.
    The hose: https://www.agencypower.com/agency-p...r-p-95903.html
    818R ICSCC SPM
  8. Thanks Brd.Prey thanked for this post
