Thread: Wiring question
    Jun 2019
    Whitehouse TX
    Question Wiring question
    Wiring question. Where does the wiring that says low beam and high beam go? I have at the dash area. I cannot find the wiring anywhere. Also, it has the right turn front, right turn rear, and everything that should be done by the Ididit steering column wiring plug. Why is it duplicated?
    Zach
    Jun 2018
    North Vancouver, BC, Canada
    I'm not quite sure what you're asking except the part about duplication - the wiring harness is a standard harness that is used in the truck, the hot rod and the roadster (likely the coupe as well). In the hot rod and truck some functions are on the ididit steering column that are actually separate dashboard switches for the roadster.... The instructions help sort out what to use and what not to use for each application.
    Gen 1 '33 Hot Rod #1104
    Jun 2019
    Whitehouse TX
    Thanks. Thought so.
    Quote Originally Posted by sperger72 View Post
    Zach
    It's a common harness for the MK4 and the 33. On the MK4, we get to deal with the steering column plug that isn't needed. My guess is that you can ignore all the duplicate connections.
    Jun 2019
    Whitehouse TX
    Thank you
