Thread: Hotrod Fuel Tank, FREE
    Placitas, NM
    UPDATE
    Last ditch effort to get rid of the tank. Today I put it on Craigslist for $45. It sold in less than 2 hrs to a guy that needed a fuel tank for his generator.
    Time to clean out the garage of parts I will not be using.
    This fuel tank is FREE, just pay the shipping from 87043 and it's yours. I pay a little of the shipping just to get it out of the garage.
    If you have a business address I can ship it to the shipping will be less than UPS or USPS. I usually use FedEx ground.
    If your remotely interested shoot me your address and I'll get you the cost for shipping which will have a discount for what I'll chip in.
    It doesn't leak, never had fuel in it, was pressure tested. I went with a different tank.
    It's very well packed, box is 15" x 13" x 49" and weighs 34 lbs.
    Maybe you can use it, cut it up to add to your existing tank for greater capacity?? It's just too good to throw in the trash.
    wallace18's Avatar
    Trenton, Florida
    Jim, I had 2 I tried to give away. No luck. I ended up recycling them to a scrap yard.
    Seasoned Citizen NAZ's Avatar
    I returned mine to FFR for credit. Along with a bunch of other parts I didn't use.
    Sacramento CA
    What is shipping to 95837
    Placitas, NM
    Just before I decided to cut it up and use it for sheet metal I threw it up on Craigslist for $45.
    It sold in less than 4 hrs.
    Sacramento CA
    I remembered this thread the other day, we have been so busy with work that i have had no time for other stuff. I thought i should go dig it up and contact you before you chucked it. Im glad you got some cash for it!
