Results 1 to 3 of 3
Thread: mustang pedal travel distance?
    I have the mustang pedal box. The clutch pedal is way to high. And the brake pedal is also too high.
    Is there any way to fine tune them? Or is the only fix an aftermarket pedal set?
    Mar 2013
    Fort Collins, Colorado
    Brake pedal can be adjusted with an adjustable master cylinder pushrod. Or add spacers between the firewall and the master cylinder. You can even make your current pushrod adjustable by simply adding a coupler nut to the center of the rod.
    https://www.whitbymotorcars.com/prod...brake-pushrod/
    Clutch pedal can be adjusted several ways, but I used this kit (in a completed car) to re-clock the square hole at the top of the pedal.
    https://www.maximummotorsports.com/C...2-93-P501.aspx
    Not all solutions have to cost an arm and a leg.
    Derald
    MK2 #3319.... On the road since 2002 with a lot of upgrades
    Clutch could also be adjusted using a firewall adjuster
    https://www.cjponyparts.com/ford-rac...RoCPagQAvD_BwE
    Summit has several brands from $37-$68
    or a cable w/ threads at the clutch end
    https://www.summitracing.com/parts/fms-m-7553-e302
