Results 1 to 2 of 2
Thread: Fitech and Sniper finishing....
    Senior Member brewha's Avatar
    Somers, Ct
    I’m curious to hear if anyone found a creative solution for storing the cable for the handheld devices that come with the new EFI units. Currently I have mine passing through the firewall, wrapped up with ties, and stuffed up in the dash where I can grab it if I need it. I think it’s clumsy and not very neat. I hate having to wrap it and re-stuff it after using it. I actually use mine more then I thought just for the data logging as I learn more about my motor.
    So what are others doing with this long snake of wire? Anyone found a creative solution?
    Mark4 - 331 Stroker - Fitech 600 -TKO600 - Moser 3.55
    Senior Member RickP's Avatar
    Boyertown, PA
    Brewha,
    I have my Fitech controller mounted via a ball mount with a 5” arm extension under my dash. Swings out of the way when I dont want to see it but is in view at my right knee when I do which seems to be 100% of the time. I ran the wire thru the firewall and and out a hole in the underdash (Mike Everson’s panel).
  3. Thanks brewha thanked for this post
