Likes Likes:  2
Results 1 to 13 of 13
Thread: Mark 3.1 for sale. Non Donor build
    Member Toy4me's Avatar
    Voorhees NJ
    [SOLD]
    This car was purchased in 2007 by a single guy with lots of disposable income. He checked off all the go fast goodies and high performance brakes and suspension. He worked on it for 2 years then got married and had 2 kids. Then the car sat due to family obligations. The car was a roller that ran but was far from finished. I bought it in 2014 and brought it home and took it all apart. I used a lot of his work but reworked a lot of what I thought was better and what I wanted. I finished it in 2016 and have only put about 2000 miles on it. This car is very fast and handles like its on rails. You can see all the parts down below and what was put into the car. I will be honest and up front on everything about this car as I want you to know everything about this car. This car is fast and it can get you into trouble very quickly. I have many more pictures and a couple of short walk around videos if need be. The car is located in Voorhees NJ. Just outside out Philadelphia Pa. $44,000.
    Thanks for looking
    Car
    Factory Five roadster series Mark 3.1.
    Dual Chrome roll bars
    Custom made fuel tank holds about 22 gallons
    Carbon fiber dashboard
    Hidden trunk hinges
    Drivetrain
    Levy Racing stage 5 408ci Windsor. 540 HP/550 ft/lbs
    Holley Sniper fuel injection
    MSD 6 Ignition system
    Headers with Gas n pipes and heat shields
    Canton road race 8 qt pan
    Levy racing Super Alloy T5 with mid shift (capable of 800 ft/lbs)
    Levy racing chrome Molly drive shaft
    Quick Time safety bellhousing
    Spec stage 2.5 clutch
    Mike Forte Hyd clutch setup
    2004 Ford SVT Cobra IRS center section with 3.55 gears Carbon fiber Trac Loc clutch pack
    Billit Flow IRS differential brace
    Drive shaft Level 5 CV axles capable of 1000 HP
    NT05 Nitto tires 315-35-17 rears 255 40 17 fronts
    Wheels Halibrand Replica Knock off
    Engine cooling
    Ron Davis High HP radiator made for FFR
    Dual Spal cooling fan setup
    Custom made upper and lower SS hoses
    Cobra Earl T stat housing
    Suspension and steering
    Levy Racing Koni double adjustable shocks F&R
    Levy Racing upper and lower front control arms fully adjustable
    Rear suspension all Heim jointed pivot points
    PS setup
    Forte’s bump steer kit
    Brakes
    Levy Racing Wilwood Superlite 6 Piston 13” front setup
    Levy Racing Wilwood 4 piston 12” rear setup
    Wilwood triple MC brake/clutch pedal assembly
    CNC Triple reservoirs
    Lokar mechanical hand brake
    Electrical
    Infinity Multiplex wiring system
    All weatherpack terminals
    Polished 1 wire alternator with 120 amp breaker
    Dashboard/cockpit
    Auto meter gauges
    Toggle switches with push button start
    5 point racing harness
    Kirkey 16 inch seats with covers and seat heaters that work!
    Misc stuff
    Wind wings and sun visors
    Keyed master cutoff switch in trunk
    Tangent hidden roll bar mounts
    Tangent Driving light kit
    FFR metal battery box sunk and hidden in trunk
    Carpeted trunk area
    FFR extended firewall
    Cobra earls powered foot box vents
    Breeze Automotive rear view mirrors
    Mechanical throttle setup
    All nuts and bolts are SS fasteners with Button heads used where (beauty) was needed
    Voorhees NJ
    I need to get a little more serious on selling this car. I just bought a new house and this will not go with me. I did not put many miles on it last year and it just needs someone who can enjoy the car more than me right now.
    May 2019
    Hayward, CA
    Looking at your past post you took Gordon Levy’s camshaft out in Feb 2017. Why did you change it and what cam did you out back in?
    Voorhees NJ
    Quote Originally Posted by Glen Davis View Post
    I took out his cam but also put his recommended cam back in. After talking to him and letting him know I was going from a carb to fuel injection he recommended a better cam for use with the fuel injection. A little less overlap to keep the o2 sensors happy and not make it run as rich. I asked if there would be any power loss. He said no it just will make it more driveable when using fuel injection. I do have the specs somewhere. If you are interested I should be able to dig them out.
    May 2019
    Hayward, CA
    Makes since, thanks.
    I was looking at building a MK4 Roadster with a Gordon Levy’s 408 engine but then I see yours for sale and thought… but with my wife in late stage Alzheimer it can be a challenge just riding in a car and even with mild acceleration in her Elantra (bought that in 2013 for her work) she freaks out sometimes so it will have to wait for now.
    One day!!!!!!!!!!!!!!!!!!!
    Voorhees NJ
    Yea with 540 HP in a very lightweight car the acceleration is downright terrifying to the unknown. This car is not HP limited it is traction limited. It will easily break the tires loose in 3rd gear with no sweat and acceleration is down right thrilling for those who expect it. These cars are not for the faint of heart.
  7. Likes Gordon Levy liked this post
    May 2019
    Hayward, CA
    There is no such thing as to much horsepower as long as you RESPECT IT!
  9. #8
    Voorhees NJ
    I think it was Carrol Shelby who said that. Never enough HP just not enough traction. Yes these cars demand respect for sure.
  10. Likes jupussin liked this post
  11. #9
    May 2019
    Hayward, CA
    I also heard - if you can lay rubber coming out of a turn all the way to the next turn braking point you have just enough power.
  12. #10
    Jan 2021
    Beautiful build! GLWS!
  13. Thanks Toy4me thanked for this post
  14. #11
    Oct 2019
    PM sent today, 3-9-2021. VERY INTERESTED, Please check PM's
  15. #12
    Voorhees NJ
    Quote Originally Posted by Hurman View Post
    Replied to your PM. Sent you my number.
  16. #13
    Voorhees NJ
    Sale is pending. I have received a deposit.
