Likes Likes:  4
Results 1 to 15 of 15
Thread: Gen 2 Floor Marine sealant FYI!
    Gen 2 guys. FYI, 3M makes the 5200 marine sealant in colors. You’re not stuck with white. Learn from my mistake.
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
    Jan 2019
    Mitchellville Iowa
    Quote Originally Posted by sethmark View Post
    I see that it’s offered in 4 colors, what would you change and why? Seepage on the bottom?
    Thanks for tips like this, I’m just getting started!
    Denny
    My floors are
    powder Coates gloss black. I’ll be picking the white sealant over run for a while once it sets.
    Titled 2-28-20
    MkI.IV 2643k
    GE makes black silicone sealant. Lowes sells it.
    The gen 2 floor uses a sandwich core and they specifically
    call out using the marine sealant and not using silicone.
    Titled 2-28-20
    MkI.IV 2643k
    Jun 2018
    North Vancouver, BC, Canada
    Once you open a tube of 5200 use as much as you can as chances are the next time you go to use it it will have already setup....
    Gen 1 '33 Hot Rod #1104
  7. Likes sethmark liked this post
    Good Lord, isn’t that the truth?
    5-7 day setup? And the stuff gets everywhere. I’m super anal and it still took an hour of cleanup.
    Titled 2-28-20
    MkI.IV 2643k
    Jun 2018
    Totally agree, I hate the stuff but it's much better than RTV and the best thing to use in marine applications...
  10. #9
    Did you ever happen to watch the TV show Dexter? That’s what I feel like I needed to do with my shop prior to using that goop. Just ball up the plastic and throw it all away....
    Titled 2-28-20
    MkI.IV 2643k
  11. Likes FF33rod, Tom Veale liked this post
  12. #10
    May 2018
    Pinckney, MI
    That's a good heads up! Time make sure I have the floor covered before I do that part of the project!
    - Peterh226 #1134
  13. #11
    Its not that it’s messy, but it gets messy quick if you screw up. I needed 5 tubes.
    Titled 2-28-20
    MkI.IV 2643k
  14. #12
    Village Mills, Texas
    Doesn't 3M make a fast cure version.
  15. #13
    Jun 2018
    Yes, fast cure is 48 hours (not fast by my definition) as compared to the standard which is 5-7 days (glacial)
  16. #14
    Jul 2019
    Anchorage, AK
    For the love of god, wear gloves with 5200! The stuff is gold though. Pro tip- if you have a pair of winter gloves take some left over 5200 and rub it between the palms of your gloves. Hang to dry and you have the worlds most waterproof, durable (and ugly) gloves.
  17. #15
    Kingsland, TX
    I looked too... I think the fast cure is only available in white. I could be wrong though.
    Quote Originally Posted by Alaskan View Post
    So kill two birds with one stone - wear your winter gloves while bonding the floor panels? (the "ugly" comment made me laugh out loud)
  18. Likes peterh226 liked this post
