Thread: Fuel Line Mod
    doddmoore's Avatar
    Mar 2018
    Jackson, MS
    Fuel Line Mod
    In the Manual it states if you are using a "high horsepower fuel injected engine" there are a few tweaks they recommend. These include drilling out the return line, and I assume going with a larger fuel hard line. My questions are several:
    1. I'll be running a Fuel Injected 347, is that going to be considered "high horsepower" enough to warrant the change? I will only run this on the street, never the track.
    2. If I do drill it out do I need to use a different fuel filter than the one in the kit?
    3. Will I also need larger fuel lines?
    4. Should I ask Mike Forte about all this since he will be building the engine?
    I guess that is it for now. I do have an update since I have FINALLY gotten back to the build. You all know how that goes. As of August 7th I am at the 1 year mark.
    "Doddmoore," Mitchell Moore on facebook, Follow Tonks347Cobra on Instagram
    MK IV Complete kit, SB Ford 347, Holley Sniper EFI, TKO 500, Moser 8.8 Solid axle, Wilwoods, Power Steering
    My Build Thread: Tonks347, The Baker's Build
    Slow and steady wins the race.
    Assuming that your pump is in or very near the tank, then no you won't need larger fuel lines to feed your 347.
    If you were running a mechanical pump on your engine (Carb) or an electric pump up front then upping the diameter of the feed line might be a good idea.
    Jun 2015
    Fairfax Station VA
    My gut tells me GoDadGo is correct, but it's certainly worth talking to Forte about. He knows engines (& these cars) inside, outside, and upside down.
    MK IV Roadster #8631
    RJD's Avatar
    Northern Virginia
    You’re running the Holley Sniper EFI right? See page 10 of the Holley Sniper EFI instruction manual - it recommends 3/8” feed and return lines.
    Quote Originally Posted by RJD View Post
    ...and if you're doing 3/8 feed and return, this is the best fuel pump holder / pickup in the land... http://www.promracing.com/fuel-suppl...-mustangs.html
    Anything else is a restriction and, well, less.
  6. Thanks RAMRobAZ thanked for this post
    Likes RAMRobAZ liked this post
    Nov 2018
    Chandler, AZ
    What horsepower are you buying? Check the EFI manual and you will see the 3/8 is needed.
    Factory Five Racing Roadster MKIV -- #9196 -- 347ci, 475 HP, 5 Speed, Plymouth Prowler Orange Metallic
    Jax Beach, FL
    Quote Originally Posted by RAMRobAZ View Post
    There you go! There are 300hp 347s and 600hp 347s. The 347 part doesn't determine how much fuel it needs. How many horses you are feeding is the determining factor.
