Thread: Heater mounting on firewall
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    I installed the Vintage Air heating unit on my firewall. It has 6 screws that joins the two halves together on each side of the firewall. The screws thread into a pretty flimsy plastic piece and seem like they could pull out without too much effort. How has this held up over time for others?
    Terry
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    I just removed mmine to install heater with A/C and it was still tight after 5 years and 9k miles.
    Walt
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
    Raleigh NC, OIB NC
    March 25, 2015 on the road - 10,000 miles still tight with no problems.
    FWIW look into an electronic water control valve with a bypass for summer driving.
    Kevin
    MKIV #8234
    So. Bay (So. Calif.)
    At the risk of being yelled at for my OCD, here's what I did. I think this was my first mod on the build. https://thefactoryfiveforum.com/show...g-modification
    Senior Member RBachman's Avatar
    Jul 2019
    Quote Originally Posted by Walt View Post
    Walt
    Walt, (also my son's name, by the way)
    Where did you get your AC/Heater and how did you install it? I'm wanting to do the same on my build, but am having difficulty finding a proven "kit."
    Thanks!!
    RB
    Dec 2013
    Navasota, Texas
    RB, i am using the a/c kit from north race cars in Missouri , aka Richard, is your car already built?
    Walt
