Results 1 to 12 of 12
Thread: Where to buy rear window for a 65 daytona ??? Need help
    Aug 2019
    Can somebody tell me where I can get the rear window for a FFR Daytona ?
    Bourne-Cape Cod, MA
    Factory five is likely the only place you will find one. They have them made specially for the car. Theirs will also likely only fit a Factory Five.
    FFinisher/AKA RE63
    Gorham, ME
    FFinisher is correct, unless you are looking for the lexan rear hatch which they don’t make anymore. That could only come through a forum member that’s not using theirs
    Making progress on the "My Coupe, my way" project.
    Coupe #386,17" Team III 245 FR 315 RR, 3-link, T5, 4 wheel disk, power brakes/steering. Fast EZ EFI
    Also, as I understand, they are different depending on the version of Coupe you have. I don't believe the current Gen 3 hatch window fits previous versions, and I've heard it's the only one available from Factory Five. Someone can correct me, but that's what I heard from someone else.
    Build 2: Mk4 Roadster #7750. Sold 04/10/2017. #7750 Build Thread
    Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017. #8674 Build Thread and Video
    Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017. #59 Coupe Build Thread
    Bourne-Cape Cod, MA
    I also Believe this is correct.
    FFinisher/AKA RE63
    At the very least the Gen3 glass has a latch hole in it that the earlier versions did not.
    Bourne-Cape Cod, MA
    Gen 2's have an odd shape cutout hole for a complicated handle. Gen 3 has a round hole for a round latch.
    FFinisher/AKA RE63
    What would it take to fab a plexiglass rear hatch?
    Could one lay a flat sheet of lexan on top of the existing glass window and with a heat-gun get it take the correct shape?
    Or just flex-fit it in there and rivet it in place?
    Gen III Coupe #17
    The first gen were a piece of lexan.
    Mar 2014
    Hi, was just inquiring with FFR about replacement for my front windshield on the coupe (all the same gen 1, 2, 3 so makes it easy). I inquired for you about the rear windshield, appears they are still available. From FFR:
    "The glass changed for the Gen 3 but the Gen is still available. (12812 = $375.00 plus shipping). If replacing the rear hatch glass piece for the Gen 1/2 only, it would be: #14886 – rear hatch glass = $499.00 plus shipping. If the rear hatch is lexan, you would need the complete rear hatch retro-fit kit which would be: #15247 = $749.00 plus shipping"
    CraigS
    The originals were plexiglass not lexan. Just like the side windows.
    Lexan has no hard cote where plexiglass does.
    As of today Lexan can be purchased with a hard coat.
    Aug 2019
    Thanks a lot !!!!
Lodestone Billetworks
