Likes Likes:  2
Results 1 to 4 of 4
Thread: No free space for engine
    Krakow, POLAND
    After engine was on place I realised that there is no free space in drive side. No idea why and what to do. Help me ... Please
    Heart of Dixie, Alabama
    When you do get clearance it will be very close. If you have correct motor mounts and SPACERS installed, with the large nuts loose and the trans mount loose, you can shift the engine slightly on the mount stands. If you still have the engine hoist on, lift the engine enough to make shifting easy. If not, you can pry between the motor mount and mount stand to twist the engine to the opposite side.
    Hope this works for you.
  3. Likes GroundPounderSATX liked this post
    Colorado Springs
    Pull the header back out and dimple the tube. You only need 1/4" or so, and it won't hurt the performance one bit.
    .boB "Iron Man"
    www.RacingTheExocet.com
  5. Likes GroundPounderSATX liked this post
  6. #4
    A very good option from Bob. I saw a video on dimpling header tubes. After marking the area, they took a round pipe, positioned on the header tube and hit the pipe. The dent takes the shape of the round pipe and not the hammer head. It looked like it was done at the factory.
  7. Thanks GroundPounderSATX thanked for this post
