Body Work Update #1 - Factory Five 33 Hot Rod V2
33 Hot Rod V2 Coupe, Extra Clearance Hood, Bike Fenders, Rear Exhaust, LS Engine
Body Work Update #2 - Factory Five 33 Hot Rod V2
Body Work Update #3 - Factory Five 33 Hot Rod V2
How to create a show car paint job - Factory Five 33 Hot Rod V2
Jim,
Glad you’re back! I enjoy your videos.
Respectfully,
Jeremie
Hi Jim
Been following along since I am at a similar stage as you are. I have done all the build primer and blocking and am having a local painter handle the seal, base, and clear.
Watching your painter friend, I was surprised not to see you folks using gloves, respirator, and at some points eye protection. These paints are some nasty things.
I like the Blue, should look really cool. I’m also hoping to get mine ‘completed’ over the winter.
Keep up the good work!
- Peterh226 #1134
33 Hot Rod with Deluxe Grill (32) Hood & sides, Bike Fenders, Hard Top, AC, Power Windows, Electric Power Steering, 306 Ford Small Block - roller cam, aluminum heads, Eldenbrock intake & carb, T5, Moser 3 link, Arrived 5/6/20.
The "standard" for this is made my Tim Whittaker - Kootenai Valley customs https://kootenaivalleycustoms.com/ his web site doesn't seem to have the various products anymore but give him a call or email....
Gen 1 '33 Hot Rod #1104
Hi Peter,
I can only speak for myself, but it is a wind tunnel and I am up stream....with a respirator.
Paint booth primer...
Paint Booth - Color - Protonic Blue
33 Hot Rod V2 Door Disassembly
33 Hot Rod V2 - Taking the Body Off
33 Hot Rod V2 - Show Car Sanding
Clean and tighten up for final build
33 Hot Rod V2 - Lizard Skin Firewall
33 Hot Rod V2 - 33 Hot Rod V2 - Firewall insulation
33 Hot Rod V2 - Interior Assembly Panels
Factory Five 33 Hot Rod V2 - Interior Assembly - Weatherstripping & Seat Belts
Rewiring the Dash Part 1
Rewiring the Dash Part 2
Transmission Tunnel Fitment
Rewiring the 33 Hot Rod V2 Dash Part 3
Painting Color on the 33 Hot Rod V2
Rewiring the 33 Hot Rod V2 Part 4
33 Hot Rod V2 Rewire Testing & Starting
Factory Five 33 Hot Rod V2 - Fit and Finish - HVAC - Door Bushings - Steering Rack Limiter
Factory Five 33 Hot Rod V2 - HVAC
Can you tell me more about the bushings you used for you door hinges? Why the change and Where do you get them?
I don't know if Jim used the same parts, but I got Delrin door bushings from Tim Whittaker (http://www.kootenaivalleycustoms.com...i=316641034576). I saw somewhere that Tim was retiring, so you might want to call him before ordering.
Keith HR #894
SRJ rarely responds to stuff so I'll chime in - it's likely Kootenai Valley customs, Tim Whittaker. He has many parts to help make a build more robust and functional including trunk supports and other items. Some are more appropriate for gen 1, others more universal. https://kootenaivalleycustoms.com/ Web site has been a bit non functional as of late but has contact info
Best to call Tim.
I bought his bump steering kit about a year ago. Very well made.
Just got off the phone with him. Great guy to talk to. Unfortunately, He's done. Going to see if he can get me that trunk kit and door bushings, and maybe one or 2 little things he might still have in a box somewhere. He did say it definitely wouldn't be anytime soon though.
If Tim really is done, he may share the bushing dimensions with the Forum community. IIRC, Delrin rods are available from McMaster-Carr and a machine shop could turn the ID and OD and cut them to the proper length.
And I agree that Tim is a great guy to talk to. He's very knowledgeable about FFR cars and freely dispenses build tips and techniques - especially if you are going to try something experimental. He once gave me a comprehensive hour long dissertation on how to build fiberglass parts, including detailed recommendations on materials, tools and techniques. Another time I got a similar tutorial on how to mount and align the body on the chassis.
Keith HR #894
Factory Five 33 Hot Rod V2 - Permanent Installation - Tunnel & Panels
Factory Five 33 Hot Rod V2 - Interior Insulation & Carpet
