someone HAS to have the maximum amount of switches - c'mon show them up on a friday night!
Wow!!! Lol... You mean that's not Photoshopped?? Keyripes!!! What on Earth did they all do?
How about this one?
Here's mine, there are 6 more switches on the lower center dash.
OK, I'll play since you didn't limit this to the roadster. I have a total of 47 "switches" but only one toggle switch. Most of mine are rockers switches or push buttons. There are 40 switches in this photo -- can you count them?
Got all 40 lol Maybe 41? Is there a brake light switch down there?
Kurt
Build thread
Wow, I missed the brake light switch in the count. There's just too many to keep track of.
I have no idea how someone can remember what all those switches do. I have enough trouble with 4. I went the other way with as few as possible. Ignition key, headlight switch, and seat heater controls are all mounted on the dash support brackets I made. Carbon Fiber Dash.jpg
Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
