Thread: rear brake hose mounting
    southern delaware
    can someone tell me if this is right for the rear brake hose? i tried putting it on 180º and it seemed to hit the halfshaf unless i bend it.
    thanks!
    Senior Member beeman's Avatar
    Indiana
    I had mine installed by previous builder per the manual. The hose was touching something (the coil over if I remember correctly) . I looked at the C5 orientation and copied it, no more rubbing.
    GTM #304 LPE 525hp LS3
    southern delaware
    could you possibly take a picture of from the back side? that way i can see how it should go. i have searched the internet for a picture of the back side but have had no luck. thanks!
    Jul 2014
    Not sure if this will help, but here is my Wilwood setup. I think I have 18 inch lines, 45 deg fitting out of the calipers and straight fitting through the wheel well wall.
    Indiana
    At full droop
  6. Thanks rolfer thanked for this post
    Likes rolfer liked this post
    southern delaware
    wow thanks!!!!!! that really helps a lot.
    you rock!!
