Results 1 to 1 of 1
Thread: Factory Five 818S #234 for sale in NH SOLD
    Senior Member JAubin's Avatar
    Goffstown, NH
    2015 Factory Five 818S
    Hollis, NH
    $20,000
    ~250 miles
    5-Speed JDM Forester XT Transmission (06) 4.44 gears, OBX LSD
    JDM STi powered - V7 EJ207 Spec-C, VF34 turbo.
    New timing belt, valve cover gaskets, oil pan, Killer-B oil pickup, plugs, water pump before dropping the motor in.
    V7 ECU tied to iWire custom wiring harness (AVCS active)
    MR-2 shifter with shortened cables and custom shift linkage.
    Prosport Turbo, Oil Press, Oil Temp, Exhaust Temp gauges
    Prosport Intercooler in/Out gauge. AEM Wideband 02
    Cobra Suzuka Pro driver seat w/ OMP 6 point harness
    Cobra Imola Pro Pass seat w/ OMP 6 point harness
    Frozenboost Air to Water Intercooler core, and front mounted heat exchanger
    Mishimoto Radiator
    IAG Air-Oil Separator
    Cobb Short intake
    STi Alloy lower control arms
    Enkei Kojin Wheels 17X8 front, 17X9 Rear w/ Firestone Indy 500 Oval tires 205/40R17 Front, 245/40R17 Rear
    Custom exhaust by WPG w/ race cat and magnaflow muffler, swaintech coated
    Life is just too busy to actually drive it as much as I'd like to (note I've had it on the road for a year). The car is running a base tune by Brentuning, as when I brought it there last year there was a transmission issue, and I replaced the original 02 trans w/ the FXT one that's in there now. The car is mechanically sorted, could use a bit of sanding or a wrap on the body, but aside from that is ready to drive. Fully titled, and inspected in NH. Feel free to ask any questions you might have, thanks for checking it out.
    Contact me at my username @gmail.com or PM.
    See build thread \/\/ for more info.
    --Joe
    818S #234 V7 EJ207 Spec-C (VF34) Build Thread
