Results 1 to 2 of 2
Thread: HELP!!! Tach Adapter 9117 Autometer COYOTE problems HELP!!!!!!! im stuck
Hybrid View
    Feb 2019
    Big Island Hawaii
    Building 35 ford truck with the Coyote motor. My problem is that my Tach is not working. I purchased an additional tach adapter 9117 in hopes that I got a faulty one but they are both acting the same......I am getting NO voltage out of the Gray wire ( the one that goes to the gauge ). The way I have it wired up is I have the Red/Green wire going to my coils (purple wire) and the Red wire going to the computer. I cut the purple wire just before the harness and split it there. I have an extremely good ground of which I have moved multiple times to eliminate that.
    Soooooo here is what I have.
    When I turn the truck on Start and ACC (without starting the motor) I get 13.3V to the Red wire which is connected to the computer
    When I start the truck ( and yes it runs which means the coils are getting voltage through the 9117 ) the voltage dips then stabilizes at 14.7volts.
    then I check voltage to the Gray Wire and I have nothing.....not with the motor running or with the motor off but with ACC on.
    Now for some reason I checked this......while the motor was running I disconnected the ground from the 9117 and all the sudden I got voltage to the Gray wire 13.3volts on ACC only....then 14.7volts fluxuating? I get the same voltage that the Red/Green wire is getting....almost identical.
    Please tell me what I have done wrong......this gremlin is killing me.
    Mahalo
    Doug
    Feb 2019
    Big Island Hawaii
    OK i am such an Idiot!!!!! I had the input and output switched.....because of how the harness was sitting in the engine bay where I spliced in the wires for the 9117 the incoming and outgoing wires looked like they were going the right direction!!!!! but they were not, I had the Red and Red Green switched.....and thus no Tach signal!!!!!! But I am jumping for JOY as I have solved my last Gremlin in my electrical system and now the body can get mounted!!!!!!! HORRAY
