Likes Likes:  2
Results 1 to 10 of 10
Thread: Dash Finish
    NY
    Dash Finish
    How did you all finish your dash ? Paint / Material ? Pic please
    Edmonton Alberta
    I used a mix of 3M stick on fake carbon fibre and black plastic (leather look) similar to the stuff that comes with the roadster kits. I attached the dash with 10-32 SS socket head screws
    David W
    Mkll 4874 built in 2004
  3. Likes timsmitaruba liked this post
    Senior Member SingleMaltWSKY's Avatar
    Jan 2016
    Went kind of a different route,
    Jonas
    _____________________
    Check out our build blog - https://vjjfactoryfive.wordpress.com/
    FFR Type-65 Coupe 720
    London Ontario Canada
  5. Likes doddmoore liked this post
  6. #4
    I'm using a combination of regular vinyl and carbon fiber looking vinyl (both matched from my Corbeau seats) and red stitching. Similar for the door cars. All fasteners hidden and not using the brow piece. Just picked up everything from the auto upholstery shop today. Should be posting pics in my build thread in the next week or two.
  7. #5
    Gorham, ME
    Aluminum covered with 1/16 foam then vinyl covering.
    Fastened with 6-32 button head Allan screws with washers.
  8. #6
    Mar 2017
    Hi David, looks nice man.
    Where did you get that shifter? Am trying to look for options, will have a mid shifter by the way.
    Anything would help, thx,
    Tim
  9. #7
    Aug 2017
    Bedford VA
    Take a look at what I did here.
    post 135 shows the near final results. several posts earlier I show the process.
    https://thefactoryfiveforum.com/show...pe-Build/page4
  10. #8
    Senior Member Alphamacaroon's Avatar
    Jan 2019
    Richland, WA
    Not finished and still very rough fitting, but I'm going for an aircraft cockpit style finish:
    Going the cheap route (which I can always upgrade later), I machined the switch bezels from plate aluminum and a handheld router in a jig, then spray painted them with BBQ grill paint. Anodizing would have been preferable, but I wanted to see how they looked before I committed. Although the grill paint with a very light sweep of a scotchbrite in one direction did a pretty good job!
    Stitch work was done by the local upholstery shop for about $240.
    Resettable fuses will fill the holes up top and a New Vintage switch panel will fill that hole in the bottom:
    Still trying to decide how I want to finish the gauge cluster.
  11. #9
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
  12. #10
    Mar 2017
    Quote Originally Posted by RBBJ 32 HOTROD View Post
    Like it! Where did you get it?
    Thx,
    Tim
