I've noticed my 2.0 engine is running pretty cool in both these areas. Oil I'm typically seeing 176*-194*F in. Not sure I've seen it get higher than that. Coolant I'm seeing 151*-165*. I'm assuming that the coolant is keeping the oil/engine from warming up since there is so much fluid in the system. The above temperatures are true after a mix of 50-60mph cruising and putting through a town at 30mph. The coolant temp is taken on the side exiting the engine (prior to radiator) and engine oil is taken at the bottom of the killer bee oil pan.
Thoughts?
