Thanks Thanks:  2
Likes Likes:  3
Results 1 to 31 of 31
Thread: Accelerator pedal question
    Senior Member UpNorth's Avatar
    Jan 2018
    Baie Saint-Paul, QC
    Hi all,
    Been scratching my head a lot this afternoon trying to figure out how to install the loud pedal.
    My gen3 will be equipped with a 347 f.i. from BluePrint. So I am installing a pedal with a good old wire to the Sniper f.i.
    But I could not figure out how/where to install/bolt the pedal so it could clear the steering column, brake pedal and firewall to its right.
    Does someone has pic of what he did? The assembly manual seems ill equipped on this.
    TIA
  2. Thanks ChicagoS thanked for this post
    Scottsdale, Arizona
    UpNorth,
    For one custom design solution (for the Ford Mustang digital Accel Pedal) check my build thread "Bob's Arizona Gen 3 Coupe Build Thread". There may be similarities you might be able to use for a cable system. The last few posts of mine address this exact issue with my design. Just yesterday I finished up the fabrication and installation and will post the last photos and comments in a day or so.
    FYI, decades ago I spent some time in Quebec City during "Winter Carnival Week", even staying at the magnificent Hotel Frontenac.
    Edmonton Alberta
    I don't have any good pictures. I used the kit pedal and Forte mechanical linkage but this does not change how the pedal mounts. I did not use the existing holes in the frame. It took a while to find a location that fit between the steering shaft and the foot box wall and then in my case adjust the pedal to push the linkage. I did start with the cable and it will fit but it took time and I used duct tape to hold the pedal in place as I tryed different locations.
    David W
    Mkll 4874 built in 2004
    Jan 2018
    Baie Saint-Paul, QC
    Hi,
    Yes Bob I saw and read your very well documented thread and I wrote this one after.
    You have a « digital » pedal as I have an « analog » one so my concern is where does the cable can get out...?
    Thanks for the kind words about my city. If you liked it during the winter Carnival (hope the weather was not too brutal) you should come back for the summer music festival, it’s awesome!
    David, thanks for the information. So I understand that there is a small flaw in the design in that area of this kit and that we need to be imaginative to find our own solution. I guess it comes with it all...I’ll try to report back with my own solution in time.
    But if someone else can share a pic or two it would be very helpful.
    Thanks guys!
    Top Notch Builder P100DHG's Avatar
    Pasadena, CA
    This is how I mounted mine.
    How the cable gets routed to the Carb/ EFI I have no idea yet. That’s my phone call to FFR for tomorrow because I’m at the at that point. Gotta finish making holes in the sheet metal before doing any finish work.
    Jan 2018
    Baie Saint-Paul, QC
    Quote Originally Posted by P100DHG View Post
    We are on the the same page. That’s what made me go hmmmm...Steering shaft is is the way big time!
    On my side I sent an e-mail with pics at FFR. Let’s share data after they respond!
    Thanks a lot!
    Aug 2018
    Mead, CO
    Watching this thread closely as I am at the same point and have the same questions.
    P100DHG, did you disassemble your peddle? I had to in order to get the lower arm on the right side of the pivot bearing.
  9. #8
    Pasadena, CA
    Quote Originally Posted by Gadsden View Post
    I remember disassembling it and realizing it can't be flipped. Maybe I changed the pivot angle but without disassembling it. That's how I remember it anyway. I disassembled it for sure attempting to do that. I don't remember how it came out of the box... Sorry.
  10. #9
    Livermore, CA
    Sorry, don't have a better pic but here is where my cable exits. I drilled through the metal that supports the steering shaft similar to how a few others have done. I was able to position the throttle pedal so the arm just clears the steering shaft and brake pedal but there's not a lot of room.
  11. #10
    Edmonton Alberta
    I disassembled it and put the arm on the right side so it fits between the steering shaft and the foot box wall. I also have it mounted higher up on the frame. But I don't have the cable so it is not exactly the same. Trying to route the cable and the connection to the FiTech is why I changed to Forte linkage.
    It sure looks like the car is really designed for the Coyote "fly by wire" pedal
    David W
  12. #11
    Jan 2018
    Baie Saint-Paul, QC
    Quote Originally Posted by Tuftster View Post
    Ok, that looks like an option! Thanks! But isn't the pedal too high for comfort?
  13. #12
    Jan 2018
    Baie Saint-Paul, QC
    Quote Originally Posted by David Williamson View Post
    David W
    Thanks Dave,
    I really wonder where the arm could fit between the fire wall and the steering shaft?IMG_2299.jpg
  14. #13
    Aug 2018
    Mead, CO
    UpNorth,
    Compare your peddle assembly to the picture in the manual. If your peddle came like mine did, I think you will see that what you have does not match the picture in the manual. If you swap the side of the pivot bearing that the lower control arm attaches to, that will shift the upper arm to the left and clear the steering shaft better.
    Hope this makes sense and we are talking about the same clash point.
  15. #14
    Jan 2018
    Baie Saint-Paul, QC
    UpNorth,
    Hi Gadsden,
    See attached pic. My upper arm is on the left side. Ball stud is on the right side of the arm.IMG_2301.jpg
  16. #15
    Here's my cable setup details.
    I spent a lot of time thinking about this, mocking it up, etc.
    The key was to use a Lokar cable with a 'centered' attachment point- it uses a pin and 2 circlips to attach to the pedal arm. This gives extra clearance to the brake pedal arm and the steering shaft.
    That, and I bent an angle near the end of the gas pedal arm.
    My considerations in doing these things were: the gas pedal in relation to the brake pedal (for heel-toe downshift/throttle blipping) and that the throttle cable exit the footbox through a section of steel near the steering shaft bearing. I did not want to have it exit through just the aluminum although to reinforce it would be easy.
    I also mounted my carburetor backwards so that the throttle cable is in a nice arc as opposed to some 'S' shape.
    The setup works very well with about 5k miles on it and my first HPDE was last weekend at Sonoma Raceway- no issues.
    Gen III Coupe #17
  17. Likes UpNorth liked this post
  18. #16
    Jan 2018
    Baie Saint-Paul, QC
    Dave,
    Thanks a lot for these pics!
    Gives me a good idea what I could do.
  19. #17
    Aug 2018
    Mead, CO
    Very timely and helpful thread! Things make a lot more sense now!
  20. #18
    Is the go pedal set up in the Gen 3 Coupe radically different, then what had been done in the previous models?
    Perhaps this area wasn't thought out very well by FFR, with what package they included in the way of a throttle pedal. Might want to look at how it was done previously. Sometimes doing it old school is better.
  21. Likes UpNorth liked this post
  22. #19
    Jan 2018
    Baie Saint-Paul, QC
    Good point AC Bill,
    Anyone with pics from previous build?
    As for my question directly to FFR the answer I got is:
    «Since the pedal position is partially discretionary on the
    driver/builders preference, you will want to place it however you wish
    based on the other pedals »
  23. #20
    Here's what I did on my Gen2 Coupe:
    From here:
    https://thefactoryfiveforum.com/show...l=1#post289297
    Pasted below:
    I ended up using the gas pedal that came with the kit, but only after a few modifications. I trimmed the edges of the pedal to make it a rectangle instead of a parallelogram to fit in the foot box better. I put a bolt through the pedal to keep it from pivoting on the spring where the pedal mounts to the arm. I also created a piece out of aluminum to mount it and double as a pedal stop. Lastly, I had read a few posts about this pedal breaking off from the mount at the spot weld points. I ended up taking the metal that was supposed to be used for the AC drier mount and wrapped it around the pivot point and mount. I then JB welded it and drilled holes in it to match the mount, then painted it over. Seems like that should hold now.
    I didn't like the throttle cable/mount that came with the kit, so I ended up getting the Lokar TC-1000U48 48" Universal Throttle Cable. This gives plenty of length to have gentle bends in the engine and also doesn't use a pivot ball to mount to the pedal. It goes right through the hole in the pedal and makes it easier to mount the pedal straight up and down instead of at some strange angle to meet the hole in the firewall.
    You can see how the Lokar cable attaches to the upper arm. Used the middle hole in the upper arm to desensitize the pedal a little and put the pedal at the height I wanted.
    You can see the screw keeping the pedal from pivoting where the pedal mounts to the arm.
    Pedal to the metal.
    If you look close, you can see the piece I put around to strengthen up the welds.
    -Matt
  24. Likes UpNorth liked this post
  25. #21
    Jan 2018
    Baie Saint-Paul, QC
    Wow Matt!
    Lots of interesting info here, thanks!
  26. #22
    Jan 2018
    Baie Saint-Paul, QC
    FF153BBD-439B-4303-A5AD-825C7756323E.jpgSo I finally did install my gas pedal see pic here.
  27. #23
    Aug 2018
    Mead, CO
    Quote Originally Posted by UpNorth View Post
    UpNorth,
    It looks like you used and existing hole for your lower bolt hole. Is that correct?
    Also, from the pic, it looks like the top or your assembly is lower than the cable hole in the front. I see your cable mount is angled, but are you getting a pretty straight pull of the cable from the front panel? if you can get a pic, i would like to see where you ended up.
    Thanks!!
  28. #24
    Is that cable angled upward at quite an angle to pass through the firewall, or just some kind of illusion, from the angle the picture was taken at?
    If it is at a sharp an angle as it appears,, hate to say it, but I bet it will start to fray before long. Better keep it well lubed. Even then, there has been the odd case of where the cable housing end gets a groove cut in it after awhile, from the cable sawing at it at an angle. This could cause the cable to stick/jam, and even the throttle return springs won't pull it free. You don't want that to happen just as your hard on the gas.
  29. #25
    Jan 2018
    Baie Saint-Paul, QC
    I did use the lower hole Gadsden.
    AC Bill, you can see from the attached pic the angle it has (sorry for the pic not being straight).
    If it’s too much I could probably drill lower than the steering shaft.
    I did drill where it is now because I could attach the cable sheath to steel instead of aluminium making it more sturdy.
    Another possibility would be to delete the ball stud attachement and invert the cable to simply have the « hammer style » ending of the cable be retained by the pedal ending hole. This could permit to deploy more the accelerator arm higher so it could match more the firewall hole I drilled.
    Is that an option?
  30. #26
    Aug 2017
    UpNorth,
    Thanks!!
    Hello Fellow Canadian!!! Im in Waterloo Ontario. As per your picture, i installed mine with the same angle too. Sadly mine is through the aluminum only.
    Now my 289 already installed and the linkage connected (570 avenger Holley Carb) i can hear the cable ride along the housing of the cable. So where there is noise, there is friction. Im thinking that lube might help but i am having this uneasy feeling that i will need to re look at it again.
    Nelson
  31. #27
    Pasadena, CA
    So I know there has been a lot of talk about the accelerator pedal in relationship to the throttle cable and the steering column and I’ve reached the point of figuring this out. I think I've come up with a clever idea. This is what I did and it accomplishes many goals, one is a straight back pull on the carb/EFI, second is a clean cable run and finally it causes zero interference with the steering column in fact it avoids the whole issue all together
    1. I drilled a 5/16 whole into the pedal mounting bracket a tight bend back toward the steeeing wheel. I have no issues with the cable’s movement.
    2. I followed the rear brake line and entered the transmission tunnel
    3. I plan to pop out of this panel to make a straight back pull on my carb/EFI
    The end result means I need to move the position of my throttle cable jobby thing on the other side of the pedal. The steering column is never an issue. Game, set, match.
    P.S. - If you hadn't noticed I am the worlds worst iPhone photographer. Literally the absolute worst. I apologize for the life of me I couldn't get the camera to focus.
    - Danny
  32. #28
    Jan 2018
    Baie Saint-Paul, QC
    Looks sharp!
  33. #29
    AC Bill, you can see from the attached pic the angle it has (sorry for the pic not being straight). If it’s too much I could probably drill lower than the steering shaft.
    I'm pretty sure that angle of pull, is going to eventually create an issue. The straighter the pull you can, get the better. Running the cable through the aluminum shouldn't be an issue, as long as your cable moves freely, and there is no extremely tight bends in the housing that could cause added resistance. The aluminum is pretty stiff at that point, as it's so close to the steel backing, that the steering column bearing is attached to. Perhaps add flat washers to either side of the footbox where the cable end passes through it, for added stiffness.
  34. #30
    Livermore, CA
    For what it's worth, I found the Fast throttle cable bracket (https://www.summitracing.com/parts/fst-304147) fits the Sniper unit in reverse so I can pull from the front side and avoid the sharp S-Bend pulling from the rear without having to turn the Sniper unit around. Haven't gotten to the point of running it yet but looks like this should work (unless anyone else points something out I'm missing).
  35. #31
    Oct 2020
    Dave, posts like this are VERY helpful as I stare at my laptop in the middle of the night. Thanks!
  36. Thanks ChicagoS thanked for this post
