Results 1 to 13 of 13
Thread: The Dart 363 is alive
Hybrid View
    Northern VA
    Still doing lots of carb tuning, but holy crap this is a lot of motor. Here it is at idle. Specs below
    https://youtu.be/zP6Fh5LTj9Y
    Compression comes out to 10.2:1.
    Heads are twisted wedge 170cc
    Rpm intake
    Brawler 600 cfm mech secondaries
    Custom cam from cam research (233/236 duration on intake/exhaust. .555 lift, and a 106 LSA)
    4.125 bore with a 3.4 stroke
    From the research and tests I have seen, my heads and carb are probably choking the motor. However, I’m sort of ok with that right now. It has excellent throttle response and is clearly faster than my 302 was, which dyno’d at 338 whp
    Now on to fix the pesky oil leak from the back of the intake manifold. First time I messed that one up. I’ll let you guys know when I scatter my T5 lol.
  2. Likes Dagwoods liked this post
    Heart of Dixie, Alabama
    Great sound with the engine. I'll bet it is quick.
    Senior Member VAHokie's Avatar
    Chantilly, VA
    Sounds great and look forward to seeing that beast in person.
    MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start 11/28/20 l First Go-kart 4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l Build Thread
    Congratulations Fellow Dart-Sider!
    Unfortunately we both know that you and I are a pair of Pros when it comes to R & R-ing a power plant.
    Congratulations Once Again & Wrench On Brother, Wrench On!
    Northern VA
    Thanks guys! And thanks Steve. I’m a happy camper man. Let’s catch up soon
    RJD's Avatar
    Northern Virginia
    Congratulations! Sounds bad @$$.
    Senior Member cv2065's Avatar
    Dec 2017
    Sounds great!!
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Sounds sweet, Scott.
    JR
  10. #9
    Northern VA
    Thanks guys!
  11. #10
    Once I had the intake at the rear wall leak. Fixed it the old fashioned way. Brake cleaned and air dried it 2-3 times. Put a glob of Ultra Grey sealer on my finger tip and smeared it on that joint. Made sure to work it into any gap. Let it dry over night. No leak. I like the Ultra Grey because it is a little thicker consistency than blue, clear, or black. Also the color hides pretty well at the edge of the aluminum manifold.
    https://www.grainger.com/product/2GX...g!456311799524!
    I don't remember if you have a compressor or not. If you don't buy a can of compressed air they use working on electronics.
    https://www.walmart.com/ip/Dust-Off-...RoClwMQAvD_BwE
  12. #11
    Northern VA
    Ahhh I soaked a towel in brake clean and cleaned it like that. Then used “the right stuff” to goop it in there lol. We will see if it works
  13. #12
    Jun 2015
    Fairfax Station VA
    Hey Scott, that engine sounds badass! Can't wait to see & hear it in person.
    MK IV Roadster #8631
  14. #13
    Alliston, Ontario, Canada
    Does sound badass. I left the stock 5.0 cam in mine, one of my regrets. Oh well I’ll build a new motor one day.
    What RPM have you got it idling at?
    2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
