Thread: 302 pulley / bracket with FFR a/c question
    NY
    Have the FFR a/c and using power steering. Id like to keep the FFR a/c bracket and purchase a bracket / pulley set from aftermarket. Any suggestions ? Trying to keep a tight budget, thanks
    Edmonton Alberta
    It does not hold a tight budget but works and looks good... I used a March mid mount A/C set up #30167. It mounts the A/C under the alternator
    David W
    Mkll 4874 built in 2004
    NY
    Quote Originally Posted by David Williamson View Post
    David W
    David, do you a picture of your setup?
    Edmonton Alberta
    picture of March mid mount AC brackets. The power steering bracket is not from the March set up, it came with the engine from Levy Racing. I used the power steering brackets from March to replace the stock Ford stuff on my Mkll.
    David W
    NY
    David W
    Thanks David, I assume you used the FFR a/c compressor?
    Edmonton Alberta
    yes the it is the FFR compressor and it is a common Sanden unit.
    David W
