Results 1 to 12 of 12
Thread: Parking Brake Handle Mounting - Picture please.
    Senior Member Slider's Avatar
    Aug 2011
    Fargo, ND
    I feel silly asking this, but could someone post a full picture of how the Parking Brake Handle Mounting Assembly mounts to the welded on Mounting Points on the Gen 3 Coupe? I've found a few "partial" pictures on the forums, but for whatever reason, I'm struggling a bit. I think it is a factor of having "extra" parts in the bag, and possibly outdated photos in the manual. Thanks in advance!
    BUILT WITH MY DAD! - MK4, 5.0 Coyote, TK0 600 with Mid-Shift, Hydraulic Clutch, Power Steering, Custom Built Stainless 4:1:4 Headers by "Stainless Headers", Dual-Rollbars, 15" Wheels, Foot Box Vents and Seat Heaters, Patriot Blue with Wimbledon White Stripes Kit arrived: June 2, 2012 - Driving: May 22, 2013
    BUILDING WITH MY DAD! - Gen 3 Type 65 Coupe, Gen3 Coyote, TKO 600, IRS, Hydraulic Clutch, PS, Stainless headers, 17" wheels, Race Seats, GPS Gauges Ordered 1-30-2019
    This is probably the best picture I have already on file showing the completed assembly installed. You're right -- the kit includes the standard set of parts for the e-brake handle including right angle mounting brackets that aren't used in this case. The pictures in the manual look OK to me, including the installation picture w/o the brackets. But agree it can be confusing if parts are left over. Hopefully this helps.
    Senior Member bil1024's Avatar
    NY
    Depends on your brake setup, you will have extra parts, especially if not using the Wilwood setup
    Aug 2018
    Mead, CO
    I have a picture of my e-brake assembly mounting in the latest posting of my build thread. It includes some updated parts that I received from F5.
    Aug 2011
    Fargo, ND
    Thank you so much. The problem is that the manual that came with my kit earlier this year, shows the image of installing it on the MarkIV. So obviously I have an outdated manual.... UGGHHHHH
    Also, the spacing on the mounting points for my handbrake doesn't work for mounting as you've got pictured above. What you've illustrated is exactly what I thought should happen, but it doesn't fit as such with the parts I have. I'll double check when I get to the shop tonight, and hopefully it's just a dumb mistake by me, but I think perhaps there is a mistake on the parts I was provided. I'll update appropriately
    My manual is REVISION 4B, OCTOBER 2017, received with my kit in December 2017. So it's not new by any means, and shows a picture somewhat like the one I posted. Sounds like you might have a newer manual? And it shows a Roadster picture of the e-brake? Strange.
    Aug 2011
    Fargo, ND
    My manual is REVISION 4B, OCTOBER 2017, received with my kit in December 2017. So it's not new by any means and shows a picture somewhat like the one I posted. Sounds like you might have a newer manual? And it shows a Roadster picture of the e-brake? Strange.
    I went to the shop tonight but forgot to look at which version of the manual I have. I'll do that tomorrow, but here is my picture of the e-brake bracket and how it doesn't fit the mounting points welded onto the chassis. The mounting points are welded at 7" on center, and the ratchet assembly has the holes at 5 3/4" on center. Unless I'm really missing something, I'm not sure how that works
    Edmonton Alberta
    I would call FFR, they have made some changes and or you have a wrong set of parts. Mine bolted up fine but I did have to cut the bolts to fit.
    David W
    Mkll 4874 built in 2004
    Agreed. Call Factory Five. Clearly something changed. My kit came with mounting holes at both locations -- 5-3/4 and 7 -- and the chassis mounts are at 7 as you found out. The manual lists the part in question as "15167 - FIXED GEAR." My kit came with one like seen in this picture from Factory Five's part catalog: http://www.factoryfiveparts.com/15183-e-brake-handle/. Obvious now why you were having problems figuring it out.
    Aug 2018
    Mead, CO
    Since it looks like you received some incorrect parts, take a look at the pic below to make sure you get all the parts you need. I did not receive parts to connect the e-brake assembly to the cables or the cable ends to the e-brake calipers. Some folks like Edwardb fabricated their own extensions, but now F5 has included the extensions.
    Aug 2011
    Fargo, ND
    Turns out that FF accidentally shipped me the ratchet gear that was intended for the '35 Truck Kit instead of what I needed for the Coupe. So it didn't fit. They are sending out the proper part today.
    Aug 2011
    Fargo, ND
    Quote Originally Posted by Gadsden View Post
    I've sent a copy of your picture to FF and asked them to confirm that they are including all these parts when they send the correct ratchet gear. Thanks for the heads up Gadsden!
