Results 1 to 4 of 4
Thread: Insulation Question
Hybrid View
    Apr 2014
    Memphis, TN
    Insulation Question
    In light of what I have read on here I have tried to take insulation very seriously. Is the lizard skin sound and heat control enough on the firewall or do I need something like the thermo-tec on top of that? Here is what I have so far:
    I have put 1/4 inch heat barrier on the exhaust starting at the firewall back to the rear exhaust of the car. I do not currently have anything on the headers. I have put the sound and heat control lizard skin on the floor pans, tunnel and firewall, and I am going to put thermo-tec on the floor pans before installing the carpet.
    Ryan
    33 Hot Rod
    Jun 2018
    North Vancouver, BC, Canada
    For what it's worth, as neither you or I have experience with the results, I am on a similar track to yourself. Lizard skin (both thermal and sound) on the firewall, and floor boards. The FFR sound and insulation package will go on top of that. Additionally, I've wrapped the mufflers in both exhaust wrap and DEI buffler shield. I am not planning on wrapping the rest of the exhaust though. I also stuffed a bit of insulation in between the frame pieces where the upper firewall goes - I have an aluminum panel on the passenger side so the insulation gets sandwiched and held there nicely. If I put other aluminum panels in the footbox (so there's no frame pieces showing), I will sandwich insulation in there as well.
    Gen 1 '33 Hot Rod #1104
  3. Likes wrp liked this post
    Village Mills, Texas
    I applied both Lizard Skin products and Dynamat to the firewall and foot boxes. Then I installed Replica Parts' inner firewall with Lizard Skin and Dynamat. Next I installed Tim Whitaker's inner foot box panels with Lizard Skin and Dynamat. The firewall and foot boxes stay now stay at ambient temperature. The floor is a whole different animal. I have the exhaust wrapped from the down pipes to past the passenger compartment, including the mufflers, with header wrap. There was no room between the floor and mufflers, on my gen 1, for a shield of any kind. I have recorded floor temperatures of 120+ degrees. But the ambient air temp. has been 95+ degrees. When I remove the seats to install the carpet, I will try another layer of Dynamat.IMG_1039.JPGIMG_1147.JPGIMG_1172.JPGIMG_1206.JPGIMG_1324.JPG
    Placitas, NM
    Wrapping the mufflers will really drop the floor temps.
    First layer
    Second layer
