Results 1 to 11 of 11
Thread: Hole punch
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    Hole punch
    In the process of building a new under dash console and need a way to punch holes with the flat on one side, what would be the best tool , that wont break the bank, to use for this?
    Its .04 aluminum.
    Walt
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
    Jax Beach, FL
    There are hand held punches for sheet metal for smaller holes. You can get them from Amazon. I haven't used one.
    For larger holes, Greenlee makes manual ones that you use a wrench on. There are probably cheap versions if you don't intend to make a living with it. Search for Greenlee punch and the cheap ones will come up also.
    Of course, drills and hole saws are the cheap and dirty way.
    Raleigh NC, OIB NC
    I am a punch & drill person. Punch a dimple & drill the hole. Are you going to cover the Console?
    Kevin
    MKIV #8234
    Dec 2013
    Navasota, Texas
    Yes, will cover with vinyl, i normally just drill but for my switchs i need the flat on one side so they dont turn.
    Walt
    Alliston, Ontario, Canada
    I’d probably use a combo of smaller drill bit, jig saw and dremel.
    2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
    Senior Member Cobradavid's Avatar
    League City, Texas
    Quote Originally Posted by Murd View Post
    ^^ What he said
    My Saving Grace: John 3:16
    FFR6687, Graduate #39 in the Class of 2009
    The Factory Five Forum March 2012 POM
    Apr 2018
    Colgate, WI
    Two cherished tools passed down from my steamfitter father. Very handy on the build. Already told me son if he does not hang on to them once I pass them down both my father and I will come back from the grave.
    Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
    May 2018
    Merritt Island, FL
    You're spending how many thousand dollars on this build?
    Do it right and get the right punch. Especially
    because you want all the holes aligned well.
    In .040 aluminum, holes with flats for switches take about 5 minutes with an undersize drilled hole and a couple of small files including a half-round. Needle files if the holes are small. I like tools as much as the next guy (and have a basement and garage to prove it) but thin 6061 aluminum is super easy and fast to work with IMHO.
  10. Likes BEAR-AvHistory liked this post
  11. #10
    Lost Wages, Nevada
    Greenlee makes a set of punches for electrical conduit knockouts . . . might be a bit large for switches though.
    Check the electronic suppliers for "chassis punches" for project boxes, they usually come in switch mount sizes and configurations.
    Doc
  12. #11
    Dec 2013
    Navasota, Texas
    Ok, thanks for the help guys!
    Walt
