Results 1 to 10 of 10
Thread: Radiator hose routing
    Jun 2019
    Whitehouse TX
    Okay, I am stuck on routing the hose to the lower radiator. Any pics or thread?
    Zach
    Nov 2018
    Scurry Texas
    Quote Originally Posted by sperger72 View Post
    Zach
    Don't know how the coyote routes but on SBC I did end up using the SS flex but routed up in between Shocks and over to a universal hose with a 90 to the water pump. It was supper tight and limits the adjustment on the radiator which in turn affects the alignment of cowl to hood. It was frustrating and took me better part of two days to get it figured out And if you've been following, I ended up hacking up the cowl to get it to fit right on the hood plane. I talked to FFR and they said that it would always have a slight angle from cowl to hood which to me is unacceptable and needs to be corrected.
    Jun 2019
    Whitehouse TX
    Thanks. I agree on the glass fitment. I am not there yet but close. Coyote fired up today for the first time!
    Nov 2018
    Scurry Texas
    Sweet. That's always exciting.
    Jun 2019
    Whitehouse TX
    Well, it starts and dies, something wrong. SBC would have been easier.
    Senior Member sethmark's Avatar
    Virginia International Raceway
    Not a truck....but similar. I’ve bent up a piece of stainless pipe. Nothing underneath the frame.
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
    Jun 2019
    Whitehouse TX
    I like it. I need a bender
    Thanks. It should polish up nicely. And leaves me with a perfectly flat bottom.
    Titled 2-28-20
    MkI.IV 2643k
    Mar 2018
    Converted mine to -20AN. Went with 1.5" 90 and -20 weld on fitting. Sits pretty tight to the frame, doesn't sit lower than the front facia/plenty of ground clearance.
    Jun 2019
    Whitehouse TX
    Awesome MArk
