Results 1 to 9 of 9
Thread: Mid shifter handle and knob options
    Mar 2017
    Friends I need your help,
    I live in Aruba so I have no local options for parts and all the other add on goodies options.
    Am getting my engine with mid shifter from Mike Forte and want a nice looking shifter handle with knob.
    Any online ideas for me to look, or tip and suggestions of course....plus any pic is more than welcome.
    Thx in advance,
    Tim
    Aruba
    Mar 2017
    Norway / Merritt Island FL
    I will be using this, Hurst 1630125
    In combination with this, Hurst 5387201
    Sigurd
    Type 65 Gen 3, 347 Fi, Tremec, IRS, Wilwood, AC, PS
    I got a solid stainless steel polished knob from SweetKnobs. He makes them to order with your specific thread pattern tapped for you.
    http://www.sweetknobs.com/
    Edmonton Alberta
    I have a Lokar shifter and I think the part number is MSL615F. The knob is a standard 3/8-16 thread and I thinkit is a Hurst 163-0108
    I also have the Forte mid shifter.
    David W
    Mkll 4874 built in 2004
    Aug 2018
    Mead, CO
    If you are getting at Termec trans, when you register, you can get a free knob/ball. I liked the options and got the white resin one and will use it. I am currently planning on using a similar shifter to Dave W, prob in the 5-6 inch height range.
    Mar 2017
    Quote Originally Posted by David Williamson View Post
    David W
    Hey David, where did you buy yours?
    Rgds, Tim
    Edmonton Alberta
    This likely won't help you but a local speed shop here in Edmonton Canada called Mopac. They have a few stores in western Canada and stock a lot of stuff.
    David W
    Millis, MA
    I’m running the same setup, only with a white knob.
    Quote Originally Posted by Sigurd View Post
    “Privateer”
    289 USRRC Chassis #9188 p/u 9/11/2017 Go kart 3/18/2018, road legal 6/16/2018
    Ford full roller 306 built by my son and me Holley Sniper EFI
    TKO600 2015 IRS 3:55. 17” FFR Hallibrand replicas, Power steering
    FFR Vintage instruments, Wipers and Heat/defrost
    Lots of parts and advice from Mike Forte & Mark Reynolds (Breeze Automotive)
    On a roll Al_C's Avatar
    Wheaton, IL
    Quote Originally Posted by chuckster View Post
    Me, too. I seem to recall someone used the same shifter, but decided to shorten it. You can cut off a bit on the bottom, and use the "top" hole of the original as the "bottom". Either way, I think this solution works pretty well.
