Results 1 to 4 of 4
Thread: AWIC Reservoir
Hybrid View
    Senior Member metros's Avatar
    NoVA
    AWIC Reservoir
    I originally built this car to have fun with at the track. I have specifically installed an oil cooler, killer b oil pan/oil pickup to support track work. After just being tuned I noticed quickly that in a cool evening drive the intake air temps increased 3-4 degrees just from doing a short run on highway on ramps (I have inlet/outlet temp probes on my intercooler). I'm wondering if I should install a water reservoir to keep the IATs cooler/longer. Planning to be able to use ice blocks in the fluid reservoir. It won't stay super cold during the whole track session but it will give a longer buffer.
    Any other builders that have tracked their car using a fluid reservoir for their AWIC? Outcomes?
    I would think the nose would be a better location as the pump is located there and could pull from the reservoir. Wonder how many gallons I could fit there comfortably.
    Senior Member Rob T's Avatar
    Woodruff, SC
    I just use the dedicated radiator in the front. I have run in very hot weather at the track. I get ambient +10F.
    Apr 2014
    3-4 degrees rise is nothing! Does it rebound quickly? I come from v8 with a2w and I’d kill for only 3-4 degree rise. And that’s with a big reservoir and such.
    Seasoned Citizen NAZ's Avatar
    We all know that AIT affects HP and there is a formula for calculating the change.
    Let’s say an engine makes 100 HP at 90F and the AIT is 120, that engine now makes 97.4 HP. In your example of a delta T of 4-deg, that would take a 100 HP down to 99.6 HP. Like Newkitguy said, that's noting! But a 20-deg change, well that could be something when the HP numbers start climbing to 500 or more. So the cost in weight penalty, complexity, and hard earned $$ to achieve a few degrees lower AIT may not be worth it unless you are competing at the highest professional level with a deep pocket sponsor.
    In the class I compete in it would be a no brainer -- not worth it!
    Chose wisely.
