Thread: Bike Fenders Clearance
    Senior Member MBB Larry's Avatar
    Feb 2018
    Grapevine, Texas USA
    I have Dan Ruth's Fenders with FFR Brackets. The Fenders and Brackets are contacting Control Arms. I have seen this on other Posts. I think I have the options are adding Steering Stops, or moving Wheels further out with Wheel Spacers. I have also seen machining down the Bracket Arms. Before I do something, I thought better to ask before proceeding. Best Options??
    FFR Hot Rod #1106
    Seasoned Citizen NAZ's Avatar
    https://www.amazon.com/1979-2004-Mus...s%2C226&sr=8-1
    Mustang steering rack limiters. Problem solved!
    Jun 2018
    North Vancouver, BC, Canada
    Larry
    I was just looking at this yesterday. Lock to lock without the fenders on has the tires about 1/2" from the arms so when I add the fenders I'll be in the same position as you. I'm going to the route Naz and others have suggested
    Gen 1 '33 Hot Rod #1104
    I should have added the number of spacers I used. Seems I bought three kits of 6ea and used most of them. If I recall, it took more on the right side than the left but that was more than a week ago. Probably should have written that down somewhere (or maybe I did) as I can hide my own Easter eggs now.
  5. Likes FF33rod liked this post
    Feb 2018
    Thanks Naz. I assume that will not decrease my Turning Radius much??
    FFR Hot Rod #1106
    Mine still turns a small enough radius that I don't remember ever having to stop and back then turn again. Then again, the fender contact really is the limiting factor not the stops.
    When I went to skinnys on the front full time I could have removed the spacers but haven't seen a need to yet. You should be fine.
    Senior Member JOP33's Avatar
    Haslet, Texas
    These are what I used (don't have the same exact set-up), but I used two on each side...
    https://www.cjponyparts.com/steering...BoCrtcQAvD_BwE
