On the 33 hotrod is the on on switch used to switch between high and low beams since our directional are on the steering column?
33 Hot Rod w/ deluxe 32 nose
350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
Order date:4/25/19, Deliver date 6/10/19
First run 10/6/2019, Go cart 11/3/2019
Correct, basically you follow the instructions in the wire harness manual (separate from the main assy manual). The wiring of it is the same as the for the roadster. I hope to be replacing it with a foot switch though. Similar to this https://www.summitracing.com/int/parts/ado-d808
Gen 1 '33 Hot Rod #1104
Cool thanks Steve. I was pretty sure but wanted to confirm that it was good enough amp wise.
Couple that stalk mounted momentary switch with this electronic latching realy and you have simple and effective hi/low switch (and cheaper than the Ididit solution)
https://www.waytekwire.com/item/7553...-State-Relay-/
Your best to run the headlights power supply, through a relay. The switch only trips the relay, using a low amperage source. Do not run the power directly to the headlights, through the toggle switch alone, or it can really heat up. Some info re doing that.
http://www.vclassics.com/archive/relays.htm
Some heavy duty headlight switches may handle the amperage draw. Also if using a factory daytime running light modem.
This is how I wired my headlight dimmer switch, which I did as a floor mount (old fashioned) setup.
Wired like this, even if the dimmer switch fails, I'll still have low-beams.
Delivered: 6/17/2017
First Start: 12/30/2017
Completed: 12/7/2019
Legal: 1/30/2020
