Results 1 to 9 of 9
Thread: On On switch for high beams
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    On the 33 hotrod is the on on switch used to switch between high and low beams since our directional are on the steering column?
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
    Jun 2018
    North Vancouver, BC, Canada
    Correct, basically you follow the instructions in the wire harness manual (separate from the main assy manual). The wiring of it is the same as the for the roadster. I hope to be replacing it with a foot switch though. Similar to this https://www.summitracing.com/int/parts/ado-d808
    Gen 1 '33 Hot Rod #1104
    Apr 2019
    Milford NH
    Cool thanks Steve. I was pretty sure but wanted to confirm that it was good enough amp wise.
    Village Mills, Texas
    Stillwater, NY
    Quote Originally Posted by HVACMAN View Post
    Couple that stalk mounted momentary switch with this electronic latching realy and you have simple and effective hi/low switch (and cheaper than the Ididit solution)
    https://www.waytekwire.com/item/7553...-State-Relay-/
  6. Likes HVACMAN liked this post
    Quote Originally Posted by RBBJ 32 HOTROD View Post
    Your best to run the headlights power supply, through a relay. The switch only trips the relay, using a low amperage source. Do not run the power directly to the headlights, through the toggle switch alone, or it can really heat up. Some info re doing that.
    http://www.vclassics.com/archive/relays.htm
    Some heavy duty headlight switches may handle the amperage draw. Also if using a factory daytime running light modem.
    Jun 2018
    That's a good thing to note Bill, we are using the LED lights so there shouldn't be a problem but if using older technology then a relay is needed...
  9. #8
    That's a good point Steve, the amperage draw should be significantly lower, with LED's. Curious as to what the amperage draw is on them?
  10. #9
    This is how I wired my headlight dimmer switch, which I did as a floor mount (old fashioned) setup.
    Wired like this, even if the dimmer switch fails, I'll still have low-beams.
