Thread: Steering Wheel adapter
    Senior Member delta0014's Avatar
    Jun 2019
    Atlanta, GA
    Anyone using a steering wheel other then Factory Five’s?
    What adapter did you use to get it to fit the bolt pattern?
    25th Anniversary Roadster #12 of 25
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
    I'm running the Grant wheel shown below:
    http://www.grantproducts.com/products/view/949/
    The adapter is a quick release piece from jegs, also shown below:
    https://www.jegs.com/i/JEGS/555/60722/10002/-1
    For the center emblem, since I'm a Chevy Guy, I used a valve cover emblem from an LT-1 Valve cover which fit perfectly:
    https://www.summitracing.com/parts/o...w/make/checker
    You can sort of see the entire set up on this old video we did a few months back along with some other off color alterations that aren't exactly period correct:
    https://youtu.be/uLmHEoWTEHg
    I'm using a Grant steering wheel, very similar to GoDad's, except mine has a yellow stripe at the top.
    The stripe is there so you have a reference for getting the front wheels straight (an *extremely* high priority when you exceed traction with the rear - if you have any idea what's good for you).
    Very little dish on the steering wheel - and smaller diameter steering wheels almost *require* power steering.
    Also very similar on the quick release - I used this one (and had to hand machine an adapter): https://www.ebay.com/itm/Longacre-52...ss!37921!US!-1
    P.S - I am very likely to change over the the Jeg's quick release - as soon as GoDad confirms that a Grant wheel bolts straight up (no adapter - I'm always looking to eliminate complications).
    Quote Originally Posted by mike223 View Post
    Confirmed Mike223,
    The 5 Screw Grant Wheels fits on the Jegs Quick Release.
    I also have an extra steering shaft if you need it since the Jegs piece welds on.
    You can see the quick release around 1:50 minutes into this video which still has my old Grant Wheel mounted on it.
    https://youtu.be/_wnHDNgnNqs
    Thanks for the generous offer Steve - I ended up with plenty of extra steering shaft after all the prototyping for the pull-a-part EPAS installation: https://thefactoryfiveforum.com/show...ll-A-Part-EPAS
    My quick disconnect mounts directly to the input shaft of the EPAS (some prototyping required - lol).
    .....I forgot about the solution that you created.
    Surely It Is The Cleanest EPS Setup Ever!
