Likes Likes:  3
Thread: Uni Steer Box Location
    Senior Member MBB Larry's Avatar
    Feb 2018
    Grapevine, Texas USA
    Anyone had any issues locating the Electronic Box in the Engine Compartment. Can be exposed to elements when running without Side Panels. Options are to splice wires and locate somewhere under Dash.
    FFR Hot Rod #1106
    Placitas, NM
    None of the electrical connectors on the box are water tight.
    I mounted my box inside, the wires just reached.
    I mounted the ps motor off the firewall.
    Jun 2018
    North Vancouver, BC, Canada
    I located the ps motor in the standard location and spliced wires to put the control unit behind the firewall near the pedal box. Like you, I didn’t want the unit exposed to the elements. Not only are the connectors not sealed, neither is the box. I will add a pic later today when I get home from Europe
    Gen 1 '33 Hot Rod #1104
    Feb 2018
    Thanks Guys, This is my original idea. Making an "Electrical Panel" to go between the AC and Brake Box. Relays, Fuse Box, Ground Strip, and put the Steering Box here. ???
    Looks better.
    FFR Hot Rod #1106
  5. Likes JOP33 liked this post
    Placitas, NM
    If I mounted it in the standard location the PS motor would be a little lower than the oil pan, which is lower than the frame.
    I didn't want to take a chance of speed bumps and the PS motor kissing each other.
    Larry, as long as you have enough space for everything that should be fine.
    wallace18's Avatar
    Trenton, Florida
    I have mounted several units just like in the manual with no problems.
    Prairieville, Louisiana
    I put mine up to left of column inside. Extended the wires to reach.
    '33 Hot Rod
    MK4 Roadster
    Jun 2018
    Here's the routing for my wires and where I mounted it. Similar to you Larry, I located a number of extra wiring items in between the pedal box and the AC unit - Sniper CD ignition, keyless ignition system and an extra 6 circuit fuse panel....
  10. #9
    Feb 2018
    Thanks All. Tomorrow I start the complete Wiring. Fire Extinguisher will be hand during power-up... :>)
    FFR Hot Rod #1106
  11. Likes FF33rod, HVACMAN liked this post
