Results 1 to 4 of 4
Thread: Indicator lights with Autometer gauges
    Senior Member RBBJ 32 HOTROD's Avatar
    Apr 2019
    Milford NH
    I'm using the Autometer gauges (not the gps vintage gauges). Which wires do you use to hook up the blinker and high beam indicator lights on the dash? The high beam one seems pretty straight forward but for the Lt and Rt blinkers do you use the indicator wires bundled with the high beam wire or the Left and right turn signal wires that are connected with the pink hazard wire? I'm also running the hotrod steering column with the wire connector.
    33 Hot Rod w/ deluxe 32 nose
    350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
    Order date:4/25/19, Deliver date 6/10/19
    First run 10/6/2019, Go cart 11/3/2019
    Jun 2018
    North Vancouver, BC, Canada
    Use the indicator wires bundled with the high beam. The signal wires bundled wit the hazard are used on the roadster not the hot rod.
    Gen 1 '33 Hot Rod #1104
    Apr 2019
    Milford NH
    Ok awesome thanks Steve. The wiring book or instruction manual weren't real clear.
    Jun 2018
    yeah, it actually helps to read some of the roadster build threads and questions to understand how the kits are different....
