Door hinge bracket help needed.
I am starting the door mounting process. I have had the cab off and on a number times now and understand why the cardboard shields are on the roll cage. The fit is tight.
With the cab off, I am installing the brackets to the frame that the doors attach to. It appears to me that the cab will be very difficult to install with the brackets on the frame. It did not appear the brackets can be mounted with the cab on; and with the cab off, they sure stick out from the frame. The only help in the manual is to mount loosely and move inward to not interfere with body mounting.
For those of you that have done this, what advice do you have? Mount brackets with cab off, somehow mount brackets with cab on, or what? The cab, particularly the back side, does not appear flexible enough to pull out the sides enough to get over the brackets.
Ralph
