Results 1 to 15 of 15
Thread: Where did you rivet your FFR name plate?
    Feb 2018
    Frisco, TX
    Where did you all rivet your name plate? Texas doesn't hand out VINs so I don't need to worry about that since the F5R serial number is on the frame. I was thinking about riveting it to the top of the removable cover on the DS footbox so it will be readily visible when you pop the hood. Where did others place it? Any pics to post?
    Copperhill, TN
    I wanted to be a bit different, so I put mine on the Breeze radiator cowl piece.
    Cape Coral, FL
    I put mine on the passenger footbox. IL issues their own VIN plate so I took the FFR plate to an engraver and got the issued number engraved before riveting it in.
    "The I.E." SoCal
    In the envelope it came in.
    __________________________
    Alliston, Ontario, Canada
    Also passenger footbox.
    Period correct!!!!
    2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    Quote Originally Posted by frankeeski View Post
    I think that's where I last saw mine too
    Build 1: Mk4 Complete Kit #9312 Ordered 1/27/18, Delivered 3/24/18, CA SB100 Registered 9/11/19 - Gen 2 Coyote TKO600, IRS, Power Steering, Wilwood Brakes, 17" Halibrand.
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
    Quote Originally Posted by lewma View Post
    Likewise..
    The govt inspection facility installs the assigned BC VIN plate, once it pass's inspection, right next to the FFR frame stamp, and i also added an AC Cars one to my left footbox.
    So. Bay (So. Calif.)
    Top of PS footbox. Plus stamped the VIN in a couple of hidden places on the frame. It was suggested by the CHP during inspection.
    O'Fallon, MO
    Bingo...... that's where mine are too.
  10. Likes frankeeski liked this post
  11. #10
    Senior Member tonywy's Avatar
    Nanticoke, Pa
    What a great question , I still can't figure where to put it. It's still in the bag on my bench.
  12. #11
    Raleigh NC, OIB NC
    Footbox
    Kevin
    MKIV #8234
  13. #12
    Mar 2017
    Spicewood, Texas
    I put mine on the drivers side of my Breeze radiator cowl cover.
    LS1, TKO600, IRS, no scoop, undercar exhaust. Delivered June 14, 2017, First start December 31, 2017, Registered and Titled Sept 12, 2019.
  14. #13
    Jax Beach, FL
    I saw it in a drawer just the other day.
  15. #14
    Dec 2012
    Houston, Texas
    I didn't get an FFR nameplate with my kit in 2001. Is this something they started sending out after that?
    Phil: FFR 3121, Frame #2050, Mk 1.5, built 2002, 1991 donor with Blueprint 302 long block and 1993 Cobra intake, BBK 70mm T/B, no smog, power steering, T-5 and 3.55 rear.
  16. #15
    Feb 2018
    Frisco, TX
    I went with the passenger footbox as well. Thanks for the input.
