Thanks Thanks:  5
Likes Likes:  4
Thread: Trimming Upper Control Arms - still recommended?
    Senior Member Traveller's Avatar
    Jul 2019
    Grand Rapids, MI
    I am working on front suspension this weekend and wanted to confirm that it is still best practice to trim about 1/8" off the rear upper adjustment sleeve on the front suspension, and also cut some off each threaded ends as well?
    I am running power steering and my understanding is that this allows you to achieve desired alignment more easily.
    Jason
    MK4 Complete Kit #9673 | Ordered: 08/07/2019 | Pickup: 08/24/2019
    Gen 2 Coyote, TKO600, IRS, Power Steering, 18" Halibrands, Kirkey Vintage Race Seats, Gas-N Headers and Pipes
    Build Thread: https://thefactoryfiveforum.com/show...IRS-Build-9673
  2. Likes GoDadGo liked this post
    Lilburn, GA
    My kit was delivered Jan 2017 and I had to trim the rear sleeve on the PS (only). I have power steering too.
  4. Thanks GoDadGo thanked for this post
    Likes Kmcallahan liked this post
  5. #3
    Yep, might as well. It's easier now than taking them apart later. The three I have helped with were limited to about +6.5 deg caster. That's OK but IMHO, minimal. I like 7.5-8.0. Also w/ normal production variation in the frame you usually max out one side, could get 1/2 deg more on the other side, but have to stop so both sides are the same.
  6. Thanks GoDadGo thanked for this post
  7. #4
    Jul 2019
    Grand Rapids, MI
    Thank you everyone. I'll cut them back now.
  8. #5
    So. Bay (So. Calif.)
    Here's some pic's of mine if it helps. I cut those on a band saw. The one that is on the spindle knuckle I used a cordless cut-off saw.
  9. Thanks GoDadGo, Traveller thanked for this post
